![]() Drives: 2019 ZLE Join Date: Jul 2020
If you track your ZL1 - exhaust tip polishing
I track my ZLE often and within the first couple of events, the outboard exhaust tips got discolored. A bit of a gold tint. They don't clean up and polish like the inboard tip. I assume the metal has permanently changed color from the heat. Has anyone been successful bringing those tip back to life and matching the inboard tips?
![]() Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
I used fine steel wool with soap and water followed by polishing compound after each event and they were like new again.
![]() ![]() Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
As the other poster stated, get some 0000 steel wool and dish soap/water and u will be gtg.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
Always had luck with this
![]() Sent from my iPhone using Tapatalk Pro
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
![]() Drives: 2023 2SS 1LE Join Date: Dec 2022
#7 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
