Jayss
Drives: 22 1ss Join Date: Oct 2018
Car had lifter tick and GM denied warranty
About two weeks ago the car started having lifter tick come from the engine while I was driving home and I had to get the car towed to the dealership that was closest to the area I was in. To preface this the car does have long tube headers and full exhaust that was put in about 8 months ago, I never got a tune done nor did I modify anything else on the drive train. The dealership just called me and told me that GM is unwilling to pay for anything under warranty and essentially I’d basically be paying for a brand new engine out of pocket. He told me I could try calling the GM customer care number and try and fight with them to get them to maybe cover it or perhaps I could take it to a different dealership and put stock headers on it and see if they can get coverage but I’m pretty sure it’s in the cars system already that the headers were replaced. Have any of you ever dealt with this before? This is my first experience with a warranty on a car and a car having this bad of an issue lol. I told him if there was a way GM has proven that the headers were the cause of the lifter tick and he said that due to the warranty being a “limited warranty” that GM can deny it due to any modification to emissions since he wouldn’t be able to complete the repair properly? I’m not sure what exactly he meant by that but I thought manufacturers had to prove the modification had to be the direct cause of the problem due to the magnusson act. I’d like to hear from anyone that has been through this and if you wouldn’t mind telling me what you did or what I can do beyond what I’ve said so far. I didn’t wanna call the customer care line before I know what to say exactly so I can at least have a chance at possibly getting this repaired under warranty.
![]() Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
Hate to say it, but I think you are out of luck with GM, given that you have headers. I doubt the exhaust, if that's all you had done to the car, would have caused them to deny you coverage. But when you mess with emissions stuff you are really taking a chance on warranty. Not sure taking it to another dealer will help since GM will have a record of your vehicle's history as soon as they run the VIN. But if you are able to swap in the stock headers it is worth a shot.
ΜΟΛΩΝ ΛΑΒΕ
![]() ![]() Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
I mean... you couldn't find the time or $500 to get a tune in 8 months?
Now, does that relate to a lifter tick, probably not. The plus though is since there is no tune (and is under a warranty) you can put the stock exhaust back on then take it to a different dealership. But with a full exhaust on the car, no dealership is going to deal with it. Yeah, you can fight it and you may luck out. But id guess more times than not, they will just tell you no. Just up to you now if the cost to take the aftermarket exhaust off, get the oem stuff put back on, then take it to the dealership to get this looked at under warranty is worth it. |
Jayss
Trust me I know, I should’ve gotten the tune a while ago I just wanted to wait until I was able to add more onto the car and didn’t expect this to happen. Idk why I put lifter tick but it’s definitely lifter knock, the car is undriveable so it would for sure be worth it to me to put the oem exhaust on it and try at another dealership if I can get the repair done under warranty. I was just trying to see if someone has maybe done this before and if it worked out or what they ultimately had to do. I know each case and dealership is handled differently I was just looking for some insight on what others have been through in this situation.
When my car had a small issue I took it to the dealership to see if there was a code mt scanner wasn't picking up. I guess cause its a zl1 their "corvette" mechanic was the only one who could look at it. He was cool and said he COULD plug the vin in, but cause it had a tune, it would void my warranty. Gave me the same option though... bring it back with the oem exhaust on and he could check it out. he was also cool enough to tell me my issue was probably the routing of my catch can hoses (which it was).
Anywho, at this point you really have 2 options take it to a reliable shop. Probably a well known performance shop and have them check it out. Or redo the exhaust and tow it to the dealer. |
#6 | |
![]() Drives: 2024 2SS Camaro Nitro Yellow Met. Join Date: May 2020
Bring up the Magnusson-Moss act 1975, sure it's been updated since then, look into this and most definotely tell the dealership of this act. How the Magnuson-Moss Act applies
#7 | |
Jayss
#8 |
Mine may be an unpopular take, but this kind of mooching is part of why vehicle and repair prices are climbing.
You modified your powertrain with long tube headers (and never tuned for them...) during your warranty period, then a few months later you got a lifter collapse on you (which is well known and to be expected with AFM, a feature that needs to be tuned out at least, or AFM lifters replaced with normal ones and a DoD hole plug applied), and now you want the manufacturer to repair or replace your engine for free. I'm absolutely no fan of GM's tactics and shenanigans, especially lately, but I think you gambled and lost, time to pick up the tab. For the record, my car is very heavily modified and if anything breaks, I know who is paying for the fix, it's yours truly, so I'm not a wine drinker preaching water. As to Magnuson-Moss, good luck with that. It was created for cases when you use an aftermarket oil filter or lightbulbs or other trivial accessories, not when you substantially modify the powertrain and, by the way, tamper with emissions equipment in the process, which alone is grounds for them to deny warranty in the first place. Modern cars have very complex designs, you cannot expect a manufacturer to cover their powertrain under warranty when third parties arbitrarily modify parts of it. Again, if I sound like a GM shill, you need to look up my post history, I hate much of what they do and the Camaro has been our last GM vehicle in the family (bought a Nissan and a Mazda since then), but the truth is the truth no matter the parties involved.
#9 | |
![]() ![]() ![]() Drives: 2023 2SS Convertible Join Date: May 2009
-Geoff
#10 | |
Moderator
#11 |
You modded the car, it's on you! Don't let the dealership fix it. Pick the car up and take it to a reputable performance shop. A lifter failure doesn't mean you need a new engine. Do a DOD/AFM delete and replace the cam and lifters. There are some stock profile cams out there that will work but I would put a mild cam in it and get a tune. The SDPC 218/228 .570 .570 114 would work. Very mild, can use stock p rods and rockers. Just need springs, lifters, DOD delete and VVT lockout kit.
#12 |
Jayss
I’ve already accepted that I’m gonna have to get it repaired on my own haha. I knew getting the headers I wasn’t gonna get approved more than likely for any warranty work and I should’ve gotten the tune but unfortunately I didn’t. But yall are all right. I mean the dealership was saying it’s a cheaper route to get a new/used engine put in it than it would be to try and rebuild the engine I have. They never opened it up to look into it and see exactly what was wrong with it but from what I saw, there’s no metal in the oil or anything. Again this is my first time dealing with any major engine problem like this and I don’t have sound clip to post unfortunately. It was a knocking sound coming from the lower part of the engine on the drivers side. I don’t want to have to pay to have a shop tear it down just to find out it’ll be a cheaper option to buy a used engine but if there’s a good chance the rotating assembly wasn’t ****ed then I’d like to go that route and just upgrade the lifters and other parts of the top part of the engine.
#13 | |
![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
There isn't any special tools needed for disassembly. Remove the intake, remove the water pump, valve covers, header bolts, head bolts. Then pull the head and you can see the lifter trays and lifters. After you can see the situation a little better then you can plan your next move. Also i wouldn't be surprised if the dealer is saying you need a new engine so that the tech can take yours and sell it. I was a dealer tech for about 8 years. They are mostly crooks. |
#14 | |
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
