Old 10-14-2025, 05:41 AM   #1
Yves ZL1
Yves ZL1's Avatar
Drives: Canadian 2019 BLACK ZL1
Oil filter bosh urgent
Hi guys
Have Some of you changed their AC DELCO Filter by a bosh?
If it’ s the case … could you tell me the exact référence ?… it’s easier her to order … thanks 😃
Yves ZL1 is offline   Reply With Quote
Old 10-14-2025, 10:09 AM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Bypass pressure matters. I'd trust Bosch to get the rest of the filter design right.
If the Bosch filter fits and has a 22psi bypass, then it's probably fine.
Old 10-14-2025, 01:44 PM   #3
MT-SS1LE
Drives: 2023 SS 1LE Sharkskin
According to ChatGPT, Bosch 3334 Premium Oil Filter cross-references to AC Delco PF64.
I have no personal experience with this Bosch filter and can't vouch that it has the correct specs. So make sure you double check yourself if you decide to try it.
ΜΟΛΩΝ ΛΑΒΕ
MT-SS1LE is offline   Reply With Quote
Old 10-14-2025, 02:18 PM   #4
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - All Bolt On's
On my 2023 Zl1, I've been using this since buying it new in Dec 2022 - ACDelco GM Original Equipment Oil Filter UPF64R. Bypass Relief Valve Setting 35.53
2023 ZL1 A10-Stainless Works 2" Long Tubes & Legend NPP Axle Back•GESI UHO 4.5" CATs•RF BigGulp•Kong 103mm & X-Ported Blower•Griptech 2.30" Upper•ATI Super Damper w/9.45" Lower•THPSI Port Injection w/875cc Injectors•FI Interchillers Stage 2•Brisk RR14S Plugs•Granatelli Malevolent Coils•Katech Low Profile Billet Valve Covers•Katech Duel Fuel Pump•MM Wild 1000HP•DSX Flex Fuel Kit•DSX Billet Lid•DMS 2gal Fender Tank•BMR Cradle Lockout•Weld Solana 18x8 Fronts/17x10 Beadlocks MT ET ST R's•Unlocked TCM•E85=785rwhp/691rwtq +21psi | 1/4=10.5005 @134.21 60ft=1.6182, 1/8=6.8373 @106.11
Old 10-27-2025, 04:59 PM   #5
Yves ZL1
Yves ZL1's Avatar
Hi guys… thanks for your help
I made it install a bosh 3334 … this was the right référence …
Just another question, but I thought it was the same the first Time … just after that changing the oil and filter… my odometer presents a various oil pressure as if it wasn’t stabilized
When you star the camaro and after she is hot what is the right oil pressure …I think it’s a bit more than 275…
Old 10-28-2025, 08:32 AM   #6
AveryReynolds
Drives: mustang 1969
Thanks for helping me out, too. You made my day.
AveryReynolds is offline   Reply With Quote
Old 10-28-2025, 09:19 AM   #7
Cold and warm/hot idle oil pressures are different, which is normal.
With the OEM oil pump, your idle oil pressure should be around 35 psi (235-240 kPa) when you cold start the car, and then it drops to 29-31 psi (200-210 kPa) once the oil is closer to operating temperature (185-195 ˚F or 85-90 ˚C).
In high pressure mode, ie when your requested torque and the resulting engine load are both high (WOT or close to it), you should see 50+ psi (340+ kPa).
These numbers are for the typical oil weights, by the way; if you run 15W-50 track oil, for example, I'm sure they will be different.
Old 10-31-2025, 04:29 PM   #8
LiquidRS
Drives: '21 Camaro ZLE
I run 5w50 Rowe oil and the oil pressure is similar to what you state above. Ambient temps range from 15 C to 45C.
LiquidRS is offline   Reply With Quote
Old 11-02-2025, 12:49 AM   #9
Jofu
Drives: 2022 Wild Cherry ZL1 1LE
Not trying to start an internet war… but how come you are using the UPF64R instead of PF64? While they have the same physical dimensions, my understanding is they have very different bypass pressure (22psi versus 35psi), so this can’t be good for the engine, right?
Geoff
Jofu is offline   Reply With Quote
