![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS Blue Join Date: Mar 2010
2019 thru 2024 Front Plate Bracket Removal Surprise
In the past I had no problem removing front plate bracket from my Camaros. Most recently I have found that in addition to the rivets used to secure the license plate bracket to the front bumper they are using adhesive behind the rivets position making it more challenging to remove the plate bracket. For 2019 thru 2024 models you may have to face 4 rivets plus adhesive behind the 4 rivets. After using a drill to remove the rivet heads (I used a 5/16 drill bit) I used a hair dryer and a little luck to lift the plate from the rivet position adhesive. On high heat for approximately 180 seconds at each of 4 rivet positions the hair dryer loosened the adhesive enough to bend the bracket and free it from the bumper. GM Part reference number 84556845 for illustration. Notice the red pull-off tabs in attached. Try at your own risk. Good luck.
![]() Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
That's pretty ridiculous to use rivets AND adhesive, never seen anything but screws used on every vehicle I've bought. I absolutely hate the look of a front plate, and so have never run one (no tickets yet, knock on wood). When I got my Camaro, I told the dealer not to install the front bracket, and they didn't. Having multiple holes in my bumper would piss me off.
ΜΟΛΩΝ ΛΑΒΕ
![]() Drives: 2024 Camaro 1SS Join Date: Mar 2024
Mine came from TN. No front plate required. No bracket, not even one in the trunk. I also do not like the look of one on the front.
No rivets, no adhesive, and no holes on my Chevy OEM front bracket. It clamps onto the grill.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions |
#5 | |
![]() Drives: 2023 Camaro 1SS M6 Join Date: Mar 2023
Not sure why it would be riveted to the bumper.
Black 2023 Camaro 1SS Coupe M6
Ordered: April 2022-----Built: July 2022-----Delivered: September 2022 -Dual-Mode Exhaust (NPP) -Red Painted Calipers (J6F) -5 Split Spoke Bright Silver Painted Aluminum Wheels (56W) -Chrome Camaro Logo Fender Badge -Second Generation Front Splitter in Satin Black |
It is a different bracket. I did order the one you are talking about, just in case I needed it ever. The one with rivets and tape is a different design. I also would not have wanted that one mine.
#7 |
![]() Drives: 2022 Camaro 2SS 1LE Join Date: Nov 2021
Front plate bracket that was on my car just screwed off no rivets or tape.
d1sc factory box w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
#8 |
Figures GM would make 2 brackets. They should know that the people who buy these cars would never want adhesive or rivets going through their bumpers.
#9 |
Front plates should be outlawed. So glad Florida doesn't use them.
2017 Camaro RS
#10 |
![]() Drives: 2016 Camaro SS Join Date: Oct 2025
Just two rivets in my 16 which was surprising to me. Thankfully the holes blend in with the dark paint.
2016 Camaro SS
#11 | |
![]() Drives: 2016 SS Join Date: Oct 2019
My 16 also had the two rivets, and upon removal now the two holes. I agree with everything going on with that grill and bumper, you don't notice. Still, kinda sucks, but I'll live. |
