Old 10-11-2025, 09:42 PM   #1
ZL1_1LE
Drives: Camaro ZL1
Shredded belt and leaking oil…
Hey everyone, not the way I wanted to introduce myself on here lol. Took the ol ZL1 out to lunch with a friend today and heard what I thought was a “pop” and then immediately smelled oil, pulled into the lunch spot and it was pissing oil but only from the two panels with holes under the car. Long story short I topped the oil off beginning of last week and didn’t drive it. It was a bit low from my previous oil change and I THINK i may have over filled the car. I had the car towed hom and changed the oil, no sparkles or chunks to speak of so I’m not sure where the oil came from. Oil pressure at idle was 30ish after the oil change. The weirdest part is during all of that mess I seemed to have shredded a belt. Not my supercharger belt, but a different one. I can attaché pictures later, but how could the two be associated with one another? Thanks for any help!
ZL1_1LE is offline   Reply With Quote
Old 10-11-2025, 09:45 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Quite a bit to unpack here. My wild guess with no pics and limited info would be you might be leaking oil out of the front crank seal or oil cooler. If that oil got in a belt maybe it slipped out of the pulley. Again, that’s a pretty wild guess lol
Old 10-11-2025, 09:54 PM   #3
ZL1_1LE
Drives: Camaro ZL1
I agree Josh, a lot to unpack and thank you for your response. I am not sure where the oil could be coming from, but do you think me over filling the oil would have caused it to come out of some where it shouldn’t have (obviously) and where should I start looking first?
Old 10-12-2025, 12:33 AM   #4
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
Definitely not caused by overfilling.
If I'd had to take a guess then I stick with a faulty front crank seal.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, Phenolic blower spacer, 82°C thermostat, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, Bronze trunnion bushings. Tuned by JRE
SpeZ is offline   Reply With Quote
Old 10-12-2025, 07:16 AM   #5
ZL1_1LE
Drives: Camaro ZL1
Ugh ok sounds like a big job. Not the type I can do in my garage I’m assuming? With your typical hand tools?
Old 10-12-2025, 07:49 AM   #6
Joshinator99
Moderator
If you’re asking that question, then it’s probably something to leave for someone else honestly. But you’re jumping the gun… you need to get under the hood and under the car and see exactly where the leak is coming from first.
Old 10-12-2025, 08:10 AM   #7
ZL1_1LE
Drives: Camaro ZL1
I agree, I know for sure there is a belt missing, I changed the oil last night and just checked the floor under the car and no reminisce of oil after the fact. Does the car need to be running for that front seal to leak? Also does anyone have a good diagram of the routing of the belts for the ZL1, i can’t find a good one for the lift of me. I’ll post a picture of which belt is shredded once the family gets up and moving haha
Old 10-12-2025, 10:43 AM   #8
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
I don't know if it applies to your engine but i see the 1.4 cruze and 2.4 equinox crank seals pop out of the front cover plate pretty often. If that were to happen then it will cover the belt in oil and easily pop off.
And yes the engine needs to run for the crank seal to leak.
Old 10-12-2025, 11:48 AM   #9
ZL1_1LE
Drives: Camaro ZL1
Thanks for the input. Looks like the belt is off what I believe to be the AC condenser. Is it in the bottom right hand corner of the engine? It’s pretty far down there and hard to reach but the pulley spins freely. What else does that belt attach too?
Old 10-12-2025, 12:11 PM   #10
bishopts
bishopts's Avatar
That belt only contacts the compressor and crank pulley. Its a stretch belt with no tensioner
Old 10-12-2025, 01:01 PM   #11
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
It can also be a pain to get on, especially without the outrageously priced gm stretch belt tool. If you need help shoot me a PM and I can give you an idea how I got mine on without any special tools.
Check out my youtube channel
https://www.youtube.com/@evans.educa...ocxUzC1ferqeg8
Full SPL suspension / Ported blower / NW 103mm / Rotofab BG / 2" Headers / Ported heads / Upgraded Valvetrain w/ DOD delete / Custom 38% Cam / C7.R Timing chain / Katech Oil pump / BMR motor mounts and chassis braces / Katech 174* Thermostat / Pierburg Supercharger coolant pump / PLM HX / JMS voltage booster / ATI Damper w/ 8.6 Lower / MM Mild catch can / ADM Resevoir / soon to come...
Rebuilt Engine / XDI +30% injectors / PWR Oil cooler setup / GMS Hood bracket
760 Whp / 700 Wtq E50
Evansa22 is online now   Reply With Quote
Old 10-12-2025, 01:34 PM   #12
bishopts
bishopts's Avatar
I think autozone sells one
Old 10-12-2025, 01:55 PM   #13
ZL1_1LE
Drives: Camaro ZL1
I’m more concerned with where the leak currently is, if i run the car without that belt on is it ok to run to watch for the leak? It obviously won’t be able to use AC, just want to run it to see if i can identify the leak.
Old 10-12-2025, 01:57 PM   #14
bishopts
bishopts's Avatar
Yea it will be fine. The more concerning thing is once you start it will it start throwing oil all over the place
