Old 10-11-2025, 09:18 PM   #1
Baddawg53
Drives: 17 hyper blue 2SS M6
New pirelli trofeo track tires
I usually only run the Hoosier R7, 315/30/18 square setup. I saw these brand new tires from pirelli which are trying to directly compete with the Hoosiers. There isn't much for reviews on these, I haven't found any Camaro owners who have tried them yet so I'm guessing I'll be the 1st. I suspect they'll be pretty similar to the Hoosier, a bit faster would be awesome, but lasting a bit longer before they fall off would be what I'm after here. I have a few days coming up in October so I think I'll have a great opportunity to see what these offer.
https://www.pirelli.com/tyres/en-ww/...r/trofeo-track
Baddawg53 is offline   Reply With Quote
Old 10-12-2025, 01:46 AM   #2
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
They sure look the business!
Dabjbr is offline   Reply With Quote
Old 10-12-2025, 10:41 AM   #3
mikedahammer
Drives: Camaro ZLE
How much do these tire run? Are you running 18x11 ET35 offset apex rims all the way around?
Edit....saw they were heat cycled by tire rack and saw pricing. Same price basically as the R7's $560-580 if anyone else was curious
Secondary question: you running 315/30/18 square?
mikedahammer is offline   Reply With Quote
Old 10-12-2025, 11:22 AM   #4
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Those guys are expensive, but should be the equal or better than R7 according to the recent Tire Rack tests. I've been using Z214s, which just dropped their DOT rating, but now also starting using scrubs for TT events. Hoosier supposed to come out with an R8 sometime. I run 315/30-18 square
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 10-12-2025, 01:39 PM   #5
Baddawg53
Yes, 315/30/18 square. They're apex 18X11 et35 sm-10 wheels with a 1 inch spacer up front. I run 3 degrees of camber, they fit great with no rubbing.
The tire rack test is the only one I found, they look promising, so we'll see!! The R7 just went up to $580/tire!! These were $15 cheaper so that difference covered the heat cycling. I believe Hoosier blamed tariffs for the increase, there's been an $80 a tire increase in a year. I couldn't be more happy that I bought a tire machine and swap my own tires, at least I'm saving there...
Old 10-13-2025, 07:39 AM   #6
mikedahammer
Drives: Camaro ZLE
Just curious with what tire machine did you purchase?
Do you not spin balance the slicks? I have heard various opinions on balancing slicks and some say that it makes no difference for a slick/track tire.
Old 10-13-2025, 08:27 AM   #7
Baddawg53
I bought it on Amazon actually. I looked for used name brand machines for a while but ultimately got this one. Having that third arm is a game changer. It paid for itself pretty quick.
I use a bubble balancer. It's good enough for me, and the weights fall off at times too.
Old 10-13-2025, 02:40 PM   #8
redfish86
Drives: GMC Sierra
These are intriguing to me. I was considering a set for my stock wheels (I have 3 sets of 19x11 apex that are all tired up at the moment). Unfortunately, they don’t offer a 285/30/20 for front duty on stock wheels. There is a 265 but going smaller in width just isn’t in my nature. (Although a 265 40 TW tire probably grips better than the stock 285 SC3 up front)
redfish86 is offline   Reply With Quote
Old 10-19-2025, 01:55 PM   #9
Baddawg53
Just a quick update on these tires.
Obviously I'm far from a professional driver, and still have a LOT of room for improvement as a driver. So take it for what it's worth ...
They're kind of a mixed bag. I was able to set a new personal best at Thunderhill east with a respectable 1:57 lap, and left there feeling like there was still plenty of time to be had. An interesting note however from that track, my speed was down on the front straight consistently about 4-5 mph. My day at Laguna Seca was very interesting, spent the first three sessions running about 4-5 seconds off my normal pace, struggling with corner exit grip, and slow speeds on all the straights. After the 3rd session I swapped to the used Hoosiers R7's immediately dropped my times 4 seconds and regained all my lost top speeds on the straights. Turns out the tires are 3 pounds heavier each compared to the Hoosiers, and that combination with not being able to get a good run out of the corners resulted in lower speeds and lost time. Overall grip seemed really good, corner speeds and Lateral G's were similar for me to the Hoosier.
Another day on Friday where the plan is to make some suspension adjustments and see if I can find some corner exit grip. It's also a short, technical track without long straights where losing the top speeds will kill your times.
Braking was very good, no issues braking deep into the zone, steering response was also very good. I think the suspension adjustments will help a lot, and ultimately the weight of the tire will be it's downfall.
Old 10-19-2025, 09:58 PM   #10
redfish86
Drives: GMC Sierra
Interesting update. Thank you OP.
Old 01-11-2026, 08:19 PM   #11
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Interesting update was considering these. Researching looks like the R7s are 27lb, the Trofeo R 28lb, and SC3R are 29lb in 305/30R19.
wakespeak is offline   Reply With Quote
Old 01-11-2026, 09:17 PM   #12
2023-SS
Drives: 2023 SS
thanks for the info & feedback on the weight.
FWIW, the best deal I ever got, automotive wise, was a buddy who ran Open Track, gave me his tires when they were "wore"
I bought a set of his used rims, put his used tires on the rims, and used them for SCCA cone racing, it was GREAT.
I was able to drive aggressively & burn up tires (the 4th Gen OEM alignment has significant toe-in to create stability in non-experienced drivers, which WEARS out front tires in SCCA) with abandon, and it really gave me alot more drip than street tires would have.
the wife even got into SCCA, since she was not burning up her street tires. it was a win-win
so if you can find an SCCA person to buy your tires which are too worn for Open Track, but still good enough for Cone Racing, that would be the ticket.
2023-SS is offline   Reply With Quote
Old 01-11-2026, 10:53 PM   #13
NG329
Drives: Chevrolet Camaro ZL1 1LE
Considering this feedback, I'm now inclined to get even lighter rims than the ones I'm currently running.
NG329 is offline   Reply With Quote
Old 01-12-2026, 10:35 AM   #14
redfish86
Drives: GMC Sierra
I got two sets. One will be staggered 325/30/19 and 305/30/19. I also got a full set to run a 305/30/19 square setup.
I really wanted to give them a little heat cycle this coming weekend at Barber so I’m ready for COTA in February, but I’m hesitant to even bring them up there as low temps will be in the 20’s. I have no experience with winter track days and tires, but I’ve read all the info I can find. Am I overthinking it?
