Old 10-08-2025, 08:54 PM   #1
Saberscar223
Saberscar223's Avatar
Drives: 2023 Riverside Blue 2SS
Results of Procharger P1X with FBO/Heads/Cam
I just got my car back from the shop with the Procharger installed, it’s been pretty great so far. With about 5.5 psi on the stock 4.13 pulley I made 645whp and 678tq. I plan on getting a 3.9 pulley installed to up the boost a few pounds. Here’s a sound clip of it https://youtube.com/shorts/jZBgU0Rmg...qRUokr0_scsbse
It has helical gears, Stage 2 Intercooler and the big red race valve.
Saberscar223 is offline   Reply With Quote
Old 10-08-2025, 09:10 PM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Nice! That is some serious low end torque!!!
Old 10-08-2025, 09:54 PM   #3
Saberscar223
Yeah I was very shocked by how much Tq it has I expected much less tq like high 500s at most with a Centrifugal Supercharger
Old 10-09-2025, 03:26 AM   #4
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Nice dude. What’s your IATs like?
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 10-09-2025, 07:31 AM   #5
18.2SS.1LE
18.2SS.1LE's Avatar
Drives: Chevrolet Camaro
Looks like they gave you someone else's dyno graph, doesn't make power like any Procharger I've seen.
Edit: there's definitely something wrong here, you're not going to be making 678 wtq at less than 3,000 RPM on a P1X setup pullied for 5.5 PSI.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
18.2SS.1LE is offline   Reply With Quote
Old 10-09-2025, 07:39 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Falling off hard up top. I would be concerned about that.
Old 10-09-2025, 11:16 AM   #7
Saberscar223
I was at pretty high elevation and that's the adjusted numbers maybe that has something to do with it? Also its pullyed for 7 psi but he said my cam and being at elevation I lose some boost.
Old 10-09-2025, 11:22 AM   #8
Saberscar223
It does seem like the power curve is much more inline with a PD supercharger rather than a centrifugal its odd because from everything I've seen ~650whp is about right with those mods.
Old 10-09-2025, 11:27 AM   #9
Saberscar223
Im getting it tuned again when I get the 3.9 pulley and a catch can so maybe it was just a sheet mix up
Old 10-09-2025, 02:33 PM   #10
18.2SS.1LE
18.2SS.1LE's Avatar
See if they can send you the correct one so you'll have results from the pulley swap.
Old 10-09-2025, 04:03 PM   #11
KingLT1
KingLT1's Avatar
Exclamation
my Whipple keeps making power with a stock cam clear out to 6500rpm.
It's laying over up top because something isn't happy.
Old 10-10-2025, 07:35 AM   #12
18.2SS.1LE
18.2SS.1LE's Avatar
Someone else's car with a PD blower wasn't happy.
Old 10-10-2025, 08:17 AM   #13
KingLT1
KingLT1's Avatar
Yeah, I just looked back at the graph again from my computer and seen you revised post. I agree with that. P1x would isn't making that much torque down low...especially with the pulley combination. 6psi peak is likely only 1-2psi down around 2500rpm.
