Drives: 2020 Camaro ZL1 Join Date: Oct 2020
What happened to radz28?
Just like the title says. He's a knowledgeable contributor regularly on here, anyone know where he's been?? He hasn't posted in nearly a month.
![]() Drives: Chevy Camaro Join Date: Sep 2022
I'm sure he'll see this and respond. We have email conversations and I owe him a reply from about a month ago. The forum itself has been falling off imo.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels. 1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically '94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake |
Yeah that's true, damn thing isn't up most of the time I try and log in. Just hadn't seen him active on here in quite some time, wanted to make sure local CHP didn't pop his hood on a weekend drive haha
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
He's kicking around... we texted each other this AM. This forum is kind of loosing it's draw and enjoyment to so. A lot of bickering and trash talking going on posts from user to user doesn't help. The good hear is to share info and learn from accomplishments and mistakes both. But, to have certain users plunge in and tear apart your build, your decisions, the way you did your build, if you did your build yourself or had a shop do it. Has even changed how much I log in. But, users like that will always be around, and we will have try to stay above that for the forum to survive. Not many new build threads are posted, maybe because the cars are already out there and being built since new ones are not being bought. But, good longevity posts/threads are still keeping traction! Seriously, I would have never imaged that my car/build post would have 618 posts and 158,990 views as of 1 minute ago!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
