![]() Drives: 2024 Camaro 1SS Join Date: Mar 2024
2ndary cat delete
What are the pros and cons to delete the secondary cat? Does anyone make pipes to do this? Thanks.
Moderator
You’ll gain about 10-15% in volume but no power gains. No one makes secondary cat delete pipes anymore to the best of my knowledge. Sometimes a set of used AWE Performance Link Pipes will pop up for sale on the forum.
Will a tune be needed?
Moderator
No. Secondary cats are not monitored by the ECM. But if the exhaust shop is not very good you’ll get a check engine light if there are any exhaust leaks.
![]() Drives: Camaro SS 1LE M6 Join Date: Feb 2024
Honestly it was my first mod before doing headers. The volume increase was minimal. Just get an axle back
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold |
Already have Borla axle back. And I AM the shop
#7 |
![]() Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
A few companies still make them if you know where to look. Small sound increase. Might gain a couple hp if any lol. Doesn’t need a tune. As long as the system is fit together, clamps are placed/tightened properly and O2s are threaded tight there shouldn’t be a check engine light. I installed one a few months ago with my AWE track (muffler delete)
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock |
#8 |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
It's a noteworthy difference in volume. For most looking for just a little bit more but don't want overwhelming, it's the way to go. IMO, it's the way it should have come from the factory, particularly those with active exhaust since you already get a "hush" mode.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
