![]() Drives: Chevrolet Camaro 2SS 1LE Join Date: Aug 2025
Steering Wheel R&R
I've had my '23 2SS 1LE for nearly a month now and have noticed that the PO drove with his hand/hands at the top of the wheel for all 7k miles that are on the clock, thus there is an area that is completely flattened and actually feels like smooth rubber. I have ordered some Adams Alcantara cleaner and a brush to try and get some nap back, but I know deep inside that I'll never be able to live with it. I can get a new wheel for $350ish but wanted to know how difficult the remove and replace is. I am a competent mechanic and have a well-stocked home shop.
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
It's not hard at all, I replaced mine with an Alcantara and carbon fiber one. Plenty of videos on youtube to walk you through the process.
![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
Pop the airbag off, then unplug the connectors that feed through the center from the clock spring. One nut holds the wheel on. It's a tapered stud so it's going to still be tight after you remove the nut. Grab the top of the wheel and pull and push really hard from just the top of it and it will release from its taper press.
#4 | |
Awesome, thanks guys.
2023 Rapid Blue 2SS/1LE
Alright, I found a few videos, actually seems easier than the old days, no gear puller required. Do you guys know the torque spec for the bolt on reinstallation? Typically, a bolt like that (at least on a Harley) would be a single use deal, is that the case with the Camaro also?
I know there's a lot of bad info on the internet but as a new Camaro guy it seems like there are a lot of hacky video makers out there doing sussy sh|t specifically on new Camaros. The video I just watched had the guy put blue Loctite back on the uncleaned bolt and bolt hole and realigned the yellow reference mark (as if it meant something) and called it good. That is some no bueno.
#7 |
#8 | |
It will be very, very tight, at least mine was, so I used a 24" breaker bar and a helper to hold the wheel steady while breaking the bolt free, with as much pressure on the head as I could muster. Torque spec for the T50 bolt is 33 lb-ft as per my 2018 service manual.
#9 |
BTW I replaced mine with this steering wheel (then also bought different CF paddles than those pictured here).
I know it's much more expensive than what you're looking for, but this is my forever Camaro and I wanted a girthier, better looking wheel that won't degrade quickly.
#10 |
USCG Retired (MKC)
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
Start with the front wheels straight, the battery negative disconnected, also leave the nut on a couple of turns while breaking loose the wheel.
#11 | |
#12 | |
https://carbonaddons.com/products/20...steering-wheel The customizability and quality of these steering wheels is spectacular, and they're 100% compatible, because the company starts with OEM cores and replaces the stock material layer by layer with the options you choose. It can even retain the heating function [for a cool $200 extra...].
#13 |
...and since I'm a hopeless tinkerer, I replaced my SS emblem with a beautiful CF inlay form 13GFab, see below.
Took a bit of work, but nothing crazy and now I have a 1 of 1 steering wheel , there were one or two too many SS badges inside and outside this car anyway.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 10-01-2025 at 08:21 PM. |
#14 |
![]() Drives: Camaro SS 1LE M6 Join Date: Feb 2024
Hey I had a similar issue with my wheel when I bought the car. I bought the Sonax cleaner and a nice brush. Watched some good youtube videos on how to "revive" alcantara and it came out very nice. I was amazed that I was able to get my flat spots to be fluffy again.
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold |
