![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
TPMS Relearn issues with new sensor
Replaced a sensor in drivers side rear tire and cannot get it to learn.
Using OEC-T5 tool, learns driver front, passenger front, passenger rear, and won't learn drivers rear. Sensor is a HUF 315/433 MHz sensor. I've set the pressure up and down on the tire a few times and driven it hoping that it was the issue, it hasn't solved the issue. Using this tool, it has always worked in the past: https://www.amazon.com/VXDAS-EL-5044.../dp/B072BK693N Using this sensor (other ones are HUF): https://www.amazon.com/BH-SENS-315MH.../dp/B08LLF84N4 It says something about programming it for the vehicle, I think this is the step I'm missing. Is this something I can borrow from an autozone/advanced auto or purchase on Amazon? Help?
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Convertible Join Date: May 2012
Maybe the new TPMS isn’t working properly? A tire shop might be able to test the it to verify if it’s working.
![]() ![]() ![]() ![]() Drives: 1970 chevelle Join Date: Aug 2011
e-brake on?
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car 2015 Z06 Z07 Daytona Sunrise Orange Metallic Dads Car 2013 ZL1 vin 963 Crystal Red Tint Coat/Black Wheels Exposed Carbon Fiber Insert 6 Spd Manual |
Last time I replaced my sensors, the tire shop told me if I brought "pre-coded" GM sensors (such as these that I'm running now), they could skip some "initial coding" step that is required for the sensors to work.
I never tried generic TPMS units before, so I'm not sure, but our fancy scan tools may support this initial programming step.
![]() Drives: Camaro ZL1 Join Date: Jun 2024
Questions
1. Do you have IGLA or a aftermarket security system installed? 2. It is not learning at all, even when using the tool from Amazon? 3. All sensors were bought at the same time? I ask these questions because I have been having the same issues with my sensors ever since I changed them out from OEM. I replaced them twice already and had better luck with my current ones, but after a certain speed or G force, they will go out and relearn again. |
...so why don't you guys buy OEM and spend your time doing more interesting things than troubleshooting crap aftermarket sensors?
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
The GM sensors are always the better choice, learned from experience on other vehicles. They batteries always last longer and there's never any issues with learning. BTW, the ZL1 sensor is all metal. You sure you got the right one??
Oh, and never buy them from Amazon or Ebay. Amazon is rife with counterfeits, and the Ebay ones, possible counterfeits too but they might be old sensors...battery life will be questionable. Buy from a source that constantly moves product, RockAuto for example.
"KEEP THE FAITH"-Fbodfather |
#8 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
When I put my new wheels on, I opted for the generic TPMS route so could keep stock tires/wheels to sell. I regretted that decision for 18 months, 2 tires would randomly loose signal and throw the fault. Day or 2 later, would work fine for a few days, rinse and repeat. Seemed to happen less often depending on time of year. When I got a new set of tires I had tire place replace them and not had an issue over the past year. I still regret being cheap initially, just annoying. Get OEM or let tire spot put what they use in and call it good.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
#9 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
You’ll either need a TPMS programming tool to set it up, or just get a pre-programmed sensor that only needs the standard relearn.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: SwissZL1 |
