Flying around Thailand
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
heater core block or bypass
Hi all, Here I am again. And once again I want to thank all of you for all the assistance you've all given to me over the years. Now I need help again, again... As some of you might know, The Aussie Camaros have a Blend Door Actuator issue. HSV has confirmed it according to forum member "Pickles". And we have to pull the dash to change the part in the wire loom. I'm not doing this if at all possible. So, I figure there is 2 possibilities for a hobbyist like me.
1.) pull the fuse if there is one for the Blend door Actuator when the door is close and it's blowing cold, which sometimes it does. OR 2.) Blocking or bypassing the heater core. Cause it's NEVER in use, ever. the warmest I make it is cool LOW fan. Because I live in Thailand where it freak'in blazing year around. Obviously if there is a dedicated fuse that would be easiest and best. But if not, how can I block or bypass the heater core? I'm sure this is possible. And if the core never receives hot Dexicool than I resolve the problem without the formidable task of pulling my dash. What think the Camaro6 forum? Thank you all again.
Mods - From JRE, the 125 RWHP Kit; From FI Interchillers, the Stage I Interchiller system, 5mm Supercharger/Head spacer plates, Heater blanket; From BMR Suspensions, Motor mounts, Cradle lockout Bushings; From Misc, Train horn in the Abandoned Heat Exchanger location using the exchanger bracket. From Banks, An I-Dash to read it all...
#2 | |
Moderator
#3 | |
Drives: 2021 ZLE, C5 Z06 6.0L Procharged Join Date: Mar 2023
LMK if you need anything from the States as I will most likely be returning next month to ship our yacht from the Port. I get two free checked bags with my flights and nothing I have brought over gets checked at Customs due to the classification of travel I am flying upon. To answer your question, you can most definitely bypass the heater core, and I can even make you a hose for that since one side is 16mm and the other is 19mm in ID. LMK! |
#4 | |
#5 | |
