![]() Drives: Audi RS3 Join Date: Aug 2022
Air Conditioning issues.
Hello from Aussie, a limited number of 6th gen ZL!s & SS's were imported into Australia & converted to RHD by the Walkinsahw Group.
Some of these cars have experienced air conditioning issues where the air cond system blows hot air out of the right hand vents, when it should be cold (at the same time remaining cold on the left hand side!). Have any of you guys experienced this sort of issue, & if you did, how did you fix it? |
![]() Drives: 1987 IROC, 2020 ZL1 Join Date: Nov 2023
Hey there,
You might want to check out this thread: https://www.camaro6.com/forums/showt...passenger+side |
#3 | |
Flying around Thailand
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
Mods - From JRE, the 125 RWHP Kit; From FI Interchillers, the Stage I Interchiller system, 5mm Supercharger/Head spacer plates, Heater blanket; From BMR Suspensions, Motor mounts, Cradle lockout Bushings; From Misc, Train horn in the Abandoned Heat Exchanger location using the exchanger bracket. From Banks, An I-Dash to read it all...
#4 | |
https://www.camaro6.com/forums/showthread.php?t=615002
#5 | |
https://www.camaro6.com/forums/showt...php?p=11136196
