Old 09-13-2025, 10:11 PM   #1
RedHotSS17
RedHotSS17's Avatar
Drives: 2017 Camaro Red Hot 2SS
Procharger Install
How hard is it to DIY install a Stage 2 P1-X Procharger with intake manifold?
And could I drive it ~5 Miles to my tuner or would I 100% need to have it trailered over?
2017 Camaro 2SS Red Hot | Speed Engineering Two Inch Catless Headers and X-Pipe | AWE Touring Axle Back Exhaust | K&N 63-Series Cold Air Intake | BMR Adjustable Sway Bars and End Links | Brisk Racing Spark Plugs | Power Stop Z26 Brake Kit
RedHotSS17 is offline   Reply With Quote
Old 09-14-2025, 07:38 AM   #2
Hammer-joe
Drives: 18 Camaro 2SS
Procharger install
Procharger install is pretty straight forward depending on your mechanical skills. The instructions are well written and have alot of pictures. I wouldn't see any problem driving to your tuner, just don't install the belt for the procharger.
Hammer-joe is offline   Reply With Quote
Old 09-14-2025, 09:04 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
You can drive it to the tuner by leaving the supercharger belt off as mentioned above unless you changed the high side fuel system. The stock fuel system isn't going to keep up with adding a P1x to your current mods unless you get a 5-6psi pulley.
KingLT1 is online now   Reply With Quote
Old 09-14-2025, 06:39 PM   #4
RedHotSS17
RedHotSS17's Avatar
So I should upgrade my fuel system to match the LT4 with a tune first and then just keep the belt off and no issues?
Old 09-14-2025, 06:49 PM   #5
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Think about your goals for the car. If you think you’re going to want to make big power at some point, buy better fuel components now (maybe Goliath HPFP plus +50 injectors or go to port injection). If you just want stock to mild mod ZL1 power then LT4 fueling is fine.
Old 09-14-2025, 07:46 PM   #6
ZO6Ted
Old badass
ZO6Ted's Avatar
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2
This! So same difference with my L87 (the good yr.) and Lingenfelter version of 2650. It ran good but not great with their kit at maybe 5-6 lb with 3-in duals cat back. Changed the pulley more or less 10 lb with lt4 fuel system. I usually run about 42% e and 93 with 100% meth as backup. King and Joshinator were a great help with awesome advice! It is stock sbe so I'm good I guess it's an eighth mile terror on the street because of four-wheel drive. I don't roll only dig bc way over 5k lbs rw. No spin just go NOW in your face! My advice don't even think about skimping on the fuel system I would just go ahead and do exactly what Josh said. If I had it to do over it would be overkill for the future because we never stop LOL but hey fbe coming after I wear this sucker out.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror
ZO6Ted is offline   Reply With Quote
Old 09-14-2025, 07:59 PM   #7
RedHotSS17
RedHotSS17's Avatar
I don't see my self passing 850, probably not much over 800.
Here is the parts on my list rn,
https://docs.google.com/spreadsheets...it?gid=0#gid=0
Old 09-15-2025, 09:16 AM   #8
KingLT1
KingLT1's Avatar
You are going to need rods and pistons for 800+ And I would not run over 550-575whp on pump gas. Ethanol will take you to 700-725whp safely on the stock bottom end, but you are going to need a lot more than the LT4 fuel system to support it with a stock cam. Port Injection is the most cost effective, or you will need FIC +30, Goliath HPFP, and a low side upgrade as well.
Old 09-15-2025, 11:07 AM   #9
RedHotSS17
RedHotSS17's Avatar
I am keeping the procharger at stock PSI for now, I am getting cam/heads/internals later, I think the stock internals can handle stock PSI.
PI
https://weaponxmotorsports.com/produ...=5922811576347
Pump
https://katechengines.com/i-30498292...ontroller.html
Injectors
https://katechengines.com/i-30498293...ectors-50.html
Replace Fuel Pipe
https://wildhammermotorsports.com/16...eneral-motors/
Flex Fuel Kit
https://www.google.com/url?q=https:/...tJbuUjvuMWSak1
Old 09-15-2025, 11:14 AM   #10
Joshinator99
Moderator
PI
Pump
Injectors
Replace Fuel Pipe
Flex Fuel Kit
I would avoid Weapon X for sure, their customer service is terrible. The TooHighPSI or DSX ones are awesome and more cost effective to boot.
Old 09-15-2025, 11:17 AM   #11
RedHotSS17
RedHotSS17's Avatar
I cant find any other kits, the results just keep showing weapon-x, is it just their customer service?
It seems like overall for now its best to procharge it first, run at a slightly lower psi and then do cam/heads/internals and fuel system later and then increase the psi
Old 09-15-2025, 01:57 PM   #12
Owl3
Drives: 24 Sliverado 1500 ZR2, 2017 ZL1
Not just their customer service. Used to be terrible at meeting promised dates, too. Almost like they needed the next order to float the funds for getting the previous orders paid for from their suppliers so parts would ship.
I eventually got everything, but if I hadn't been sent on a 2-year out of town work assignment I would have been very upset.
Seems like I read a post recently about them just coming back up on line after some company problems.
Finally on the way to 1K.....
Owl3 is offline   Reply With Quote
Old 09-15-2025, 02:28 PM   #13
KingLT1
KingLT1's Avatar
https://toohighpsi.com/
https://dsxtuning.com/products/atlas...jEunH8cQp52X15
Since you are going procharger, you don't need port plates if you buy a manifold (BTR) that has injector bungs already drilled for port. You would just need the Atlas or Reflex controller, harness, injectors.
