![]() Drives: 2021 LT1 10 Speed Join Date: Apr 2020
BTR Trinity Mid Length Manifold Dyno Results
2021 LT1 10 Speed
BTR Trinity Mid Length IM SE 1 7/8 Headers 103mm TB Rotofab Flex Fuel - was about 81% E content Done on a hub dyno around mid 70 degree weather 457.9 whp / 430.8 tq did not lose any low end either, both me and my tuner we're actually suprised with how much power it made and how much power it kept through out all the rpms |
![]() Drives: 2022 Vivid Orange LT1-M6 Join Date: Dec 2015
I thought HUD Dynos are higher than Dynojet? Who knows how they are setup.
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph |
#3 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
The second photo was the first time I got tuned back in april and all I had done was LT2 IM and flex fuel and that was with timing and fuel added because I was running lean so baseline probably sat at 370-380, i peaked 420whp with just the LT2/E setup as well.
Moderator
Negative. Dynojet uses an inertia drum and is not load bearing so the Dynojet numbers are typically the highest. Load bearing (like a Mustang Dyno)typically read the lowest and hub dynos are usually somewhere in the middle (since they aren’t losing power to tire slip).
![]() Drives: LT1 Join Date: Apr 2024
The setup sounds great! Looks like hp stays relatively flat to 6500 rpm, but it's hard to tell from pics.
Generally speaking, has the BTR trinity mid-length IM had much testing? I wonder how the setup would respond to a mild cam, e g., BTR 220, with valvetrain upgrade. Perhaps 7500 rpm? |
#7 |
https://www.instagram.com/p/DKM_OWTt...03MWc1NTMzNXNk
Nice comparison between short and mid runners.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
Mid length fits under the hood?
#9 |
#10 |
![]() Drives: 2021 Camaro LT1 Join Date: Sep 2025
Just installed BTR Mid-Length on my 2021 LT1 A10
7/8 LTH with Cats, Cold Air Inductions CAI, E85 Flex Kit, NW 103mm TB, Tune Ran 503 HP 442 TQ on Dynocom Baseline was 410 HP Stock |
#11 |
Do you have a screenshot of the baseline?
#12 |
https://www.facebook.com/groups/chev...7366244882595/
This is why I don't trust Dynocom numbers at all. Edit - this is the same shop FYR Solutions, in Las Vegas, and for the above post and the Facebook link. You can look at the car above (in the link) on Facebook running a 12.8 at the track.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph Last edited by vince3; 10-03-2025 at 08:28 AM. |
#13 | |
Patiently waiting for someone to try this manifold with a cam. Upgraded valvetrain and worked head would also be a good data point. |
#14 | |
the 12.8 at The Strip in Las Vegas, no prep, with stock run flats in July with 5578 ft DA. A stock camaro SS run mid 13's all day long. You can check how some other cars were running that day: https://youtu.be/M5jB_BOPE-s?si=IBykfOPWiQn_ZYcC https://airdensityonline.com/track-r...otor_Speedway/ Today, I will take it to the same track, forecasted DA 3652 ft. BTR, E85 pump, and ET Streets SS. I'm hoping 12.0, possibly 11.9. The BTR definetely moved the HP higher on the RPM for sure. I will post what happened after tonight. |
