Old 09-11-2025, 11:18 AM   #1
Wolfman1
Drives: 2019 Camaro ZL1
Question Throttle Lag
2019 ZL1 A10; Can someone explain the throttle lag from part throttle to wide open throttle? When I 'punch it' from just about any speed this thing lags like it has turbos instead of a supercharger. Bogs and then comes on like gang busters.
Wolfman1 is offline   Reply With Quote
Old 09-11-2025, 05:32 PM   #2
The A10 wants to downshift first, but even then it shouldn't be that bad.
Here's a trick: blip the throttle to the floor first (as if the pedal was a switch), or take a few turns very aggressively, which will engage Performance Shift Mode on the trans, bringing and keeping the revs in the powerband around ~4K, and then punch it. The car should start hauling the mail immediately.
Old 09-12-2025, 03:44 AM   #3
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
If its changing gears in automatic mode, that's normal as mentioned. It's not a DCT so there will be a delay when it has to change from 8th-10th gear to 3rd gear.
Put it in manual mode, hold the RPM's at 3000-4000 and then punch it when its in the right gear. Is there still a delay when you do this?
GM Gen V Calibrator
Old 09-13-2025, 10:06 AM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
Mine has never had any lag, but it's in the tune. Who tuned it?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
