Old 09-08-2025, 03:05 PM   #1
19Nasty1le
Craig
19Nasty1le's Avatar
Drives: 2019 ZL1 1LE
NPP won’t work?
Just swapped my Corsa Extreme+ system for the Corsa NPP axelback to quiet the car down a bit after mods but the valves are just staying wide open they don’t respond to any mode selection. Has anyone had this happen before by chance when going back to a NPP exhaust?
I’ve asked the tuner, they claim it’s not shut off or tuned out. I don’t have a unlocked MVPI tool, is it accessible without unlocking again does anyone know? I’ve checked the fuses and the wires are all plugged in but the motors never spin, even tried another set of actuators.
PFA
19Nasty1le is offline   Reply With Quote
Old 09-09-2025, 12:55 PM   #2
calypso50kid
Drives: 2018 zle, 03 cobra, 92 mustang lx
did you go into the setting on the radio home screen and go to the driving modes and change it to auto where it will change with the modes on the center console? someone may have changed it to be in track all the time.
Owner and driver of the worlds fastest naturally aspirated drag radial car. Hays Consulting and Performance
4.58@151 BBC powered 585 ci 9000+ rpm
https://youtu.be/wSz2OedlNSI?si=SnPoqreXFQ7NLYX8
2018 ZL1 1LE 416ci LME long block, 2650, reflex port injection, full e85, tick performance tr6060, monster triple disc, DSS drive shaft, g force axles.
calypso50kid is offline   Reply With Quote
Old 09-09-2025, 01:26 PM   #3
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
If I remember correctly, and I could be 100% WRONG. I think this happen when I installed my Corsa Xtreme, the actual valves where in the opposite position when I installed the NPP actuator / controller on the muffler. I removed the NPP, changed the position and then reinstalled?
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 09-09-2025, 10:34 PM   #4
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
This is probably a really really stupid question, but I've got to rule it out anyway since your stuff is not working. Did you make sure your actuators are even plugged in? I had an issue with one of my exhausts where the smoothbrain who did the work for me forgot to plug it in and I didn't catch it until I was home staring at the setup wondering why it wouldn't shut up despite attempts to put it in stealth mode.
758 HP/ 804 TQ
Old 09-10-2025, 06:38 AM   #5
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
check fuse 50 or 51 that isn't blown or removed. I can't recall the exact fuse number the NPP is on.
Old 09-10-2025, 12:20 PM   #6
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I think it is 51...
Old 09-11-2025, 06:00 PM   #7
19Nasty1le
Craig
19Nasty1le's Avatar
So I checked… I was looking at 43 because I saw Exh Vlv lol 51 was missing so tossed a 15 in but now when I turn the car to ACC (to move valves before car starts) it sounds like this until I select “stealth” on the touch screen
https://youtube.com/shorts/k56SOEE6q...drb3G_-WLCdpmf
