Old 09-07-2025, 11:06 AM   #1
DansZL1-1LE
DansZL1-1LE's Avatar
Drives: Chevy Camaro ZL1 1LE
Question ZL1 1LE being towed on the side of the road
It has not happened to me, but I am concerned if I break down on the road and a flatbed carrier shows up, that the ramp angle will be too steep and damage my Splitter. Does anyone have experience with being towed (unplanned)?
The Manual says to adjust the Strut Spring. Reading the procedure, that is not realistic with a tow truck on the side of the road.
Thanks!
DansZL1-1LE is offline   Reply With Quote
Old 09-08-2025, 05:35 AM   #2
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
I had my car picked up on a flat bed when the oil pump failed, the guy knew what he was doing.
He put pieces of wood in front of the ramp to lift the front of the car up before it hit the incline.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 09-08-2025, 06:09 AM   #3
NashZL1
Drives: 2022 Camaro ZL1
Had my 2022 non-ILE ZL1 towed. Same experience as post above. No damage.
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10
2020 Ford Mustang Shelby GT500
2020 Genesis G90 Ultimate
2018 Porsche 718 Cayman GTS
2019 Mercedes-Benz SL450
2017 Corvette Grand Sport A8
2024 Honda Civic Touring
1971 Datsun 240Z
NashZL1 is offline   Reply With Quote
Old 09-08-2025, 06:40 AM   #4
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
+1 to both above. When my drive shaft snapped, the guy new what car he was towing, brought extra 2x8 wood to easy the flatbed to road gap, it was perfect! I did tell the dispatch person when I called. My car is very low in front and they need to be sure it doesn't scrap the tow bed while being loaded.
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
