Old 08-31-2025, 11:18 AM   #1
p47dman
Drives: 2024 Camaro 1SS
Oil Filter
What oil filter does everyone use? First change I used TG 10575 this time I had XG 12060.
p47dman is offline   Reply With Quote
Old 08-31-2025, 11:25 AM   #2
beowulf556
Drives: Camaro SS 1LE M6
I use the AC Delco that the manual recommends
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is offline   Reply With Quote
Old 08-31-2025, 11:28 AM   #3
p47dman
If I am not mistaken that is the same as 12060.
Old 08-31-2025, 11:38 AM   #4
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
I only use the OEM, which is the PF64. Genuine quality with tested and safe bypass pressures.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, CHE trunnion bushings. Tuned by JRE
SpeZ is offline   Reply With Quote
Old 08-31-2025, 01:01 PM   #5
Deacon Blues
Drives: 2024 Camaro 1SS M6
Same. I've read a lot of concerns about other brand filters and bypass pressure. I figured it was best to stick with Delco.
Interestingly, I started down this road because I bought the PF64 Gold and then read that it didn't have the same pressure as the standard filter, so even within the AC Delco world there is consternation. So I went with the exact same model filter that came off from the factory, and that's what I've done for each change.
Deacon Blues is offline   Reply With Quote
Old 08-31-2025, 04:44 PM   #6
2018 Blue 1LE
2018 Blue 1LE's Avatar
Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M
PF64 or WIX LD-WL10290XP, I just put on the WIX yesterday.
Watched a youtube video that went through the alternate filters and the WIX was a close enough bypass pressure to be considered the same.
Many of the others are either significantly higher or lower.
2018 Blue 1LE is offline   Reply With Quote
Old 08-31-2025, 10:06 PM   #7
I use Amsoil's EA15K50 filter
Old 09-01-2025, 12:13 AM   #8
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
If you are under Powertrain Warranty, ACDelco PF64.... I've been using them exclusively since day 1...
Old 09-01-2025, 11:27 PM   #9
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
The PF64 is the ONLY filter for the LT1 or LT4 wetsump engines. Anything else you want to use, even the WIX or Amsoil filters have to be carefully selected due to the bypass in the filter AND there is another bypass in the block that will close off flow to the oil cooler circuit as well.
Here is the link to the different filter and their ratings. LMK if you have any questions.
https://patriotmotorsportsusa.com/pr...42107520221282
Patriot Motorsports USA is offline   Reply With Quote
Old 09-02-2025, 01:44 AM   #10
2SS Capt
2SS Capt's Avatar
ACDelco PF64...
Old 09-03-2025, 08:31 PM   #11
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Only ever used ACDelco PF64, and have no reason to change.
Old 09-03-2025, 11:25 PM   #12
David, you yourself allow for a Wix and an Amsoil filter at this link and note their superior filtering capabilities, so this post looks a bit overly cautious---of course non-OEM filters always have to be "carefully selected", but nobody who cares enough to go beyond the ever varying PF64 would just slap in a random oil filter, right?
Old 09-04-2025, 02:54 PM   #13
p47dman
Thanks to all for the replies. arpad, yes I try to choose carefully about all my vehicles. The Pete's engine is $65,000. Fleet Guard for her. I actually had an AC filter fail on me years ago. Not on a Camaro. Nor an LT engine. I just put 6000 miles on the last filter, Fram 10575. Had no problems. I am now just over 10,000 miles with hopefully many more to come. Dave.
Old 09-05-2025, 10:10 AM   #14
tbair64
tbair64's Avatar
Drives: 2022 Camaro LT1
Only WIX for me. WL10290
tbair64 is offline   Reply With Quote
