![]() Drives: '20 ZL1 M6 Join Date: Apr 2017
need tires
I've been getting my tires from Tire Rack and usually stay with the Supercar 3's, but the rears are out of stock with no estimate on arrival from Goodyear.
So, I've used Michelin PS4S's before and I liked them. But, the test I read on Tire Rack's site raved about the Conti Extremecontact Sport 02's, and I'm leaning towards giving them a try. Thoughts from those who have used both?
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
I have Nitto R555R2's and they hooked great on the street, hit clover leaf's on the free way at higher than expected speed, 50mph, 60mph. Very low road noise too. Cold weather they don't hook like any other tire, but nice weather they were great! Then I got to a bigger rwhp, and ended up with Weld beadlocks with Mickey Thompson ET Street R's and they HOOOOK ! great in good weather!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
![]() Drives: 2023 2SS 1LE Join Date: Oct 2021
Hi ZX, I have a little of 2K miles on the Conti ExtremeContact 02s. I really like them. They are not like the SC3's but they are responsive. I also live in FL and wanted something that worked well in the rain. The Continentals live up to my expectation. You can push them and they feel secure. The ride is quiet but not like you are riding on marshmallows. I think you will be satisfied the Continentals for street driving.
2023 2SS 1LE Radiant Red, A10, PDR, Black Lugs, ACS Rock Guards, ACS ZL1 1LE Side Skirts
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
PS4S is the standard for ~300tw summer tires but Conti, Pirelli and GY all have comparable tires these days, you can't go wrong with any of them.
#5 | |
![]() ![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
I really like the Yokohama Advan Apex V601. They are really good tires that warm up quick. They work very well in the rain (I've been 100+mph) and they are very confidence inspiring. I've had them to 170mph in the dry. I run my cold pressures at 30-32psi in the Summertime, and 28-30psi in the winter. You can find these on Tirerack for about $1,200 for the entire set. |
![]() Drives: Camaro ZL1, Golf R Join Date: Feb 2022
It looks like Discount Tire has the OEM sizes in stock for the GYSC3.
FWIW I did not like the MPS4S and switched back to the GYSC3. The sidewall is much softer than the GY and it lost a lot of the front end feel the car has at the limit. It just felt soft and disconnected. A lot more understeer too. IMO That said they were quiet, comfortable, and it was nice not hearing rocks pelt the side of my car. But I didn’t buy it for any of that, so GYSC3 it is for me. I am curious about the Continental ECS though.
’22 ZL1 Riverside Blue 6MT
’17 Golf R Limestone Grey DSG |
#7 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
I have the Conti Sport 02 and love them. Great traction on wet roads
#8 |
2022 Vivid Orange ZL1 1LE
Drives: Firebirds - 1970,1974,1997,1999 Join Date: May 2018
I have used all three on the track. Supercar 3's, Michelin PS4S's, Conti Extremecontact Sport 02's. Of course, the Supercar 3 wear fastest. The Extremecontact Sport 02 wear much slower with about the same performance. Of course, your experience will vary depending on your skill level and driving style. I use the PS4s on high speed open road races, such as Silver State Classic Challenge (125 mph class with 138.72mph trap speed) and Nevada Open Road Challenge (140mph class and 158.01mph trap speed). The PS4's have a higher load rating which is suggested for open road racing.
These cars love the track and open road. PS 40 track days and two open road races |
