Old 08-22-2025, 04:50 PM   #1
beowulf556
Drives: Camaro SS 1LE M6
How to connect catch can to LT2 manifold
So I just put on my lt2 manifold and decided to get a catch can after seeing oil build up in the heads. I'm debating on how to connect the catch can now. I bought a 90 degree fitting which worked great with the hose I made for the lt2. The catch can comes with the quick connect fittings. I'm wondering if anyone has found a 90 degree adapter for the lt2 intake that will work with quick connect fittings? If not, I guess my only option is to cut the fitting off the catch can hose and just clamp it on? Trying to make it as clean as possible!
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is online now   Reply With Quote
Old 08-23-2025, 02:10 PM   #2
DeuceCam
Drives: LT1
Put the hose in the sun for a bit. You'll probably be able to pull the fitting off when it's hot as the hose will be more pliable. Then push the hose on the barb on the 90* fitting.
DeuceCam is offline   Reply With Quote
Old 08-24-2025, 02:11 PM   #3
beowulf556
Here is what I ended up doing, simple hose clamp.
Old 08-24-2025, 06:18 PM   #4
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
I have the Mishimoto catch can with the quick fittings and bought these from Amazon. They fit perfectly.
https://a.co/d/7BuAXhn
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods
BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune
BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP
LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete
Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit
SSShark is online now   Reply With Quote
