Old 08-21-2025, 12:06 PM   #1
2017HyperSS - MO
Drives: 2017 Camaro 2SS M6
M6 fault codes PO729 PO731 PO733 PO734 PO735
Has anyone had these codes? My car is M6 and these codes are coming up pretty steady. The car has no symptoms otherwise, but this causes me to lose this gear indicator in the dash (and HUD). It also disables the back camera which I hate.
On a related note, I have had Redline Synthetic D4 atf in the transmission for about 8000 miles now. The codes started about 1000 miles ago.
Any help would be appreciated!
2017 Camaro 2SS, M6, Mag Ride, Pearl Stripe, NAV/Bose, Bright Silver Wheels.
2017HyperSS - MO is offline   Reply With Quote
Old 08-22-2025, 06:33 AM   #2
Ray3768
Ray3768's Avatar
Drives: 1977 Trans Am, 2024 Camaro 2SS
P0729 = Gear 6 Incorrect Ratio
P0731 = Gear 1 Incorrect Ratio
P0733 = Gear 3 Incorrect Ratio
P0734 = Gear 4 Incorrect Ratio
P0735 = Gear 5 Incorrect Ratio
If you feel like throwing parts at it, try this:
https://www.gmpartswarehouse.com/oem...ensor-24296964
Certainly check the wire harness and connector for bad connections prior to purchasing the part.
How do you like the Redline D4 trans fluid? Any improvements? I saw a significant improvement when I did this to my 2012 SS. Since my 6th gen transmission shifts so much better than the 5th gen trans I am hesitant to swap the fluid to anything but the factory fluid.
-Ray
Ray3768 is offline   Reply With Quote
