Long hauler
Drives: 2022 Camaro 2SS 1LE Join Date: Mar 2017
Thought this would be some fun bits of information.
Only including US spec cars, ordered by trim hierarchy: 1LS - $6,995 Total Options 1LT - $16,105 Total Options 2LT - $15,810 Total Options 3LT- $18,230 Total Options LT1- $23,030 Total Options 1SS- $22,235 Total Options 2SS- $24,130 Total Options (Highest overall cost in options) ZL1- $15,020 Total Options ZL1 G56- $15,490 Total Options (Technically the largest non-CE optioned car, 56 identical cars) ZL1 1LE - $15,960 Total Options ZL1 Collectors Edition - $24,120 Total Options (#174, #133, and #150 are tied as identical)
2016 1LT v6 - Totaled Happiness: Infinite Last edited by Bumbleboy92; 08-21-2025 at 12:12 AM. |
Long hauler
Images of the cars
2016 1LT v6 - Totaled Happiness: Infinite |
![]() ![]() ![]() ![]() ![]() Drives: 2012 Shelby GT500 Join Date: Jan 2020
The 2022 LT1 had a bunch of 1LE parts and had about 6k in options of 1LE parts. Also had the tech pack. It would have been cheaper to just order a 2SS 1LE
Please tell me how you got the images!!!
2012 Shelby GT500 with VMP Gen 3R.
Prior: 2023 Camaro 2SS 1LE 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
#4 | |
Long hauler
I found that similar to the window sticker API, GM has an image generator API for all their vehicles. It’s what they use on the vehicle builders online and for images on their inventory search and owners center. The trick is, it runs on RPO codes so I took all of the RPO codes from a given window sticker and made them into the correct format for the image generator API. There’s a few more views per vehicle, the 2LT and LT1 with RS package is broken on their end as the base headlights overlap the RS headlights. I haven’t really advertised it (especially since I never fully deployed it LOL), I’ve been working on this site. Bear with the red flags and slowness, I’m no expert in full stack dev https://www.gmbuildcounts.com/
2016 1LT v6 - Totaled Happiness: Infinite Last edited by Bumbleboy92; 08-21-2025 at 07:02 PM. |
#5 | |
It would have been awesome if the images were still in front of the fake chevy dealership but beggars can't be choosers ![]() I had gotten all my RPO codes from the excel files with all the 2020-2024 consolidated build counts and actually took the time to google the codes. Your tool however amazingly listed them all out for me! Do you know if "sticker creation date" is the build date of the car? I have something similar and very different built out in Tableau that breaks down specific build counts/combinations.
Something else I just noticed was on my car it's showing the hashmark on the hood which I did not have ordered on my car, and the mirrors are body color instead of satin.
#7 |
Long hauler
Thank you for the kind words, I found that they changed the angles/number of images per year and model, 2022 and prior had slightly different angles photos than 2023+. 2023+ also added a wheel photo that previous years didn’t get. I set the background to be transparent on the API, normally appears to be a grey background without the transparent option. I’m sure there’s more options I haven’t discovered with it though.
The sticker creation date isn’t the build date, it’s a strange bit of info they included but typically the sticker creation date is about a week or two after the build date. Guess whatever they use to make the stickers just tacks it on when a sticker is generated. I also noticed the lack of satin mirrors for my 1LE, I’ll play with the options to see if it can be added. The hashmark’s on mine as well even when it’s not ordered. I think the image API has that hardcoded to the A1Y RPO for some reason.
#8 |
Long hauler
Looks like another gift from the image API for both the hashmark and mirrors. 2019 SS 1LE is perfect, 2020+ loses the satin mirrors and 2022+ adds the hashmark for whatever reason. Then 2024 removes the hashmark but didn’t fix the mirrors
![]() Checked the RPO’s passed to the API and the hashmark RPO (D88) isn’t passed for 2022-2023 but always appears when A1Y is passed. Edit: Fixed the 1LE satin mirrors, the hash mark I don't think can be fixed as the A1Y RPO adds it and when I delete A1Y the mirrors change to body color again
2016 1LT v6 - Totaled Happiness: Infinite Last edited by Bumbleboy92; 08-21-2025 at 02:39 PM. |
#9 |
![]() Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
That tool is really cool! Found my car! Really cool to have the computer generated images of my car now. I'm collecting all these files about my car in a folder so these will be nice to add to my collection
![]() I only saw a handful of cars optioned like mine in the list, do you think this tool is pretty accurate in that I could assume just that many are in the country configured like mine? Thanks for posting this! |
#10 | |
Long hauler
I made it so that you can filter down your specs on the main table, then you can search for the RPO codes your car is optioned with in the search bar above the table. Clicking on a RPO in that field will filter for cars with that RPO as well. Personally I’d check this thread and then use the RPO code that matches there on the search bar as the source because the RPO descriptions I’m sourcing are typically generic and not tailored to just Camaro. https://www.camaro6.com/forums/showthread.php?t=420366 Getting down to every option will make all cars 1/1, like mine is 1/9 and if I add the optioned floor mats it’s 1/1 then. There are cars not on the data like the build counts on the forums, that’s just GM not uploading non-NA cars and some exceptions they decide not to upload for whatever reason
#11 |
![]() Drives: 2023 Camaro Convertible ZL1 A10 Join Date: Mar 2023
What about a ZL1 Convertible any option there?
#12 |
Long hauler
The Collectors Edition takes it easily there lol The normal ZL1 convertible is also the most expensive ZL1 convertible of all years. ZL1 Collectors Edition Convertible - $22,345 Total Options ZL1 Collectors Edition Convertible - $22,345 Total Options ZL1 Convertible - $8,795 Total Options ZL1 Convertible - $8,795 Total Options
#13 |
![]() Drives: 2023 Camaro LT1 6-Speed Join Date: May 2022
Wow, this is really nice work!
I spent countless hours playing with all the different combinations before I got my car. I was a bit sad when the GM websites got rid of the Camaro. |
#14 | |
Long hauler
https://www.chevrolet.ca/byo-vc/clie...ro/2024/camaro Thank GM Canada for that, until they phase it out as well
2016 1LT v6 - Totaled Happiness: Infinite Last edited by Bumbleboy92; 09-11-2025 at 11:04 PM. |
| Tags |
| highest, options, price |
