Old 08-20-2025, 11:24 PM   #1
SheetzNo.1Fan
Drives: 2019 2SS 1LE
Exclamation Random Misfire/Running Rough
Hey all, I'm at a complete loss as to what is going on with my 2019 2SS 1LE. 99.9% stock, has a cold air intake. No tunes. 23,000 miles.
It randomly started having a misfire one night after an easy cruise session. It would throw codes for bad O2 readings (too rich and too lean), "Service Stabilitrack" and "Service Rear Axle" would come up on the dash, and it would put itself into almost a limp mode.
I gave it to a Chevrolet dealer to look at. They replaced fuel injectors, O2 sensors (all of them), ECM, and spark plugs. They said it ran fine for a few minutes but then started running rough again and they noticed that one of the upstream O2 sensors was dropping out randomly.
They have had the car for FOUR weeks. I really need to hear from someone that has had a similar problem like this or someone that knows more about Camaro specific problems than I do.
Thanks
OBD codes before taking to dealer.
U0401-71
-ECM invalid data
U042B-71
-CCM invalid data/lost communication
P0157
-Bank 2 Sensor 2 low voltage
P0175
-Rich condition Bank 2
P015A
-Delayed O2 Bank 1 Sensor 1
P0430
-Bank 2 catalytic converter inefficient
P0300
-Random misfire
P0132
-Bank 1 O2 high voltage
SheetzNo.1Fan is offline   Reply With Quote
Old 08-21-2025, 07:15 AM   #2
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
A bad battery can cause random codes to pop up. How old is the battery?
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 08-21-2025, 07:16 AM   #3
SheetzNo.1Fan
New battery installed right after issue began. Did not improve anything.
Old 08-21-2025, 07:40 AM   #4
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Change the oil. The oil might be full of fuel from the injector failure. Also the high pressure fuel pump could be leaking fuel into the oil. Ive seen that on a few of the 6.2 trucks
Old 08-21-2025, 07:44 AM   #5
SheetzNo.1Fan
The dealer still has it. I changed the oil soon after it started running rough and didn't notice a smell of gasoline or a drastic change in the viscosity. I did change the injectors before I took it to the dealer and primed it several times and there wasn't any leaks from the high pressure fuel pump.
Old 08-21-2025, 07:56 AM   #6
Z28GTOSSMike
Drives: 2019 Camaro 1SS
I had a similar problem with the O2 sensor going bad and it killed the catalytic converter on one bank. After the second O2 replacement I replaced the converter and haven't had any further problems.
Z28GTOSSMike is offline   Reply With Quote
Old 08-21-2025, 08:21 AM   #7
bishopts
bishopts's Avatar
You could try a different dealership. Maybe one that has a tech that knows what he is doing.
Old 08-21-2025, 08:54 AM   #8
SheetzNo.1Fan
I had a code for a bad catalytic convertor on bank 2 for a brief moment.
Old 08-21-2025, 09:31 AM   #9
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Thanks
Your Dealership is also at a complete loss as they simply do not get the training needed to deal with the complexity of these cars. I had to learn everything by immersing weeks of testing at the track alongside those who were tasked with developing these systems and trying to break through my own reservations of trusting the technology to punch through the mental difficulties and the physical ones when something went wrong!
The typical response for the menu alerts you received is indeed the battery, in most every instance, but there are other triggers for the same alerts. What you also need to look for are the suspension travel sensors to be sure they are all connected and that they are all within the same range of adjustment when the car is sitting level. IF, you have a PERFECT wheel/tire/suspension alignment and I mean a ZERO thrust angle with at least 1/8" Toe-In, you CAN adjust these sensors to impact the torque vectoring of the eLSD. The image below is from the Patent GM submitted to obtain controlling manufacture of the eLSD used in the Camaro, Corvette Z06 & ZR1 vehicles. You can see there are dozens of sensors all being utilized JUST to keep your car focused exactly where you POINT IT. The problem is... these sensors also impact the tuning of the engine, can cause random misfires as the ECU is also taking road surface data to adjust torque output. This sometimes can come across as a misfire when a sensor is failing and making an intervention without a clear cause for it.
On Jeremy's Pikes Peak car, we were getting the same alerts you are, but also had an issue where the right rear tire would break free and just spin like an open differential. This all came down to the front right plastic link on the control arm's travel sensor broke free and fell to a fully down position.
If your SS1LE is equipped with the eLSD, I would suggest looking for any indication of wheel speed or angle sensors are outta-whack... make adjustments as needed, if any and also add a ground cable to the engine from the chassis by the fuse box. We offer these cables, ready to install with marine-grade silver-tinned copper stranded wire, copper ends and sealed with heat shrink. This cable offers better starting when hot and better ground path for all electronics, including your battery to deal with all the data necessary to operate a clean CanBus of information.
Hope this helps!
Patriot Motorsports USA is offline   Reply With Quote
Old 08-21-2025, 09:42 AM   #10
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
At this point I would try replacing the cat on the side where the upstream O2 sensor is acting up. It is not unheard of for cats to go bad on these cars. Also you have an 8 year 80k mile emissions warranty for make sure you don’t foot the bill on the cat replacement.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 08-21-2025, 09:57 AM   #11
SheetzNo.1Fan
I called this morning and asked if they would check it with a bore scope.
Old 08-21-2025, 11:01 AM   #12
ctrlz
I think they should drive this car and do some live data logging. Is there a real pattern to what's going on, or is it more random? Random might mean a loose connector or wiring problem.
This is low miles with no significant mods, and they already threw parts at it.
Bad converter at 23K miles? doubt that.
EDIT: Bad MAF connection after the CAI install? Intermittent MAF can give you O2 sensor codes.
Old 08-21-2025, 11:20 AM   #13
SheetzNo.1Fan
They have been driving it to look at live data. They had to send live data to GM and they recommended that the ECM get replaced last week. The original testing that they did showed that the injectors were bad so that was the first thing that got replaced then they saw all the O2 sensors because the readings were adjusting the fuel trims too much. They did update me today and said they found a faulty connection with a sensor and had to drive it to see if it would start missing after correcting the connection. They've inspected the harness and that was all they found.
Old 08-21-2025, 11:29 AM   #14
SheetzNo.1Fan
UPDATE
Called the dealer and they said the misfire is gone but a code for the catalytic convertor came on and nothing else. Asked about the emissions warranty and they're looking into it while I come pick it up.
#help, #misfire, #roughidle
