Old 08-17-2025, 02:24 PM   #1
Zachapapa
Drives: 2016 Camaro ss manual
Can a 21 zl1 tr6060 fit into a 16 ss
Will there be anything I need to change putting a 2021 zl1 tr6060 into a 16 ss or is it just direct plug and play
Zachapapa is offline   Reply With Quote
Old 08-17-2025, 06:02 PM   #2
RedHotSS17
Drives: 2017 Camaro Red Hot 2SS
Assuming yours is already manual, it should be the transmission you already have so yes, if you have an auto, it can be swapped but its alot of work.
RedHotSS17 is offline   Reply With Quote
Old 08-18-2025, 06:27 AM   #3
Ray3768
Ray3768's Avatar
Drives: 1977 Trans Am, 2024 Camaro 2SS
SS vs ZL1 M6 gears ratios are different:
https://www.camaro6.com/forums/showthread.php?t=584316
1-3 are numerically lower for the ZL1 M6. This would be helpful if you are supercharged or plan to be.
-Ray
Ray3768 is offline   Reply With Quote
