Old 08-15-2025, 04:40 PM   #1
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
keep and eye on those control arms
Into the second year of tracking just replaced the front lower control arms. Easy to tell, leaks oil around the bushing. I wish I had the time to wait for SPL parts but had to go OEM for track days over the next week.
dpevans is offline   Reply With Quote
Old 08-15-2025, 08:34 PM   #2
nikerret
Drives: 2014 Ford F-350
How much track time do you have?
2024 Red Hot 2SS 1LE w/BCD, PDR
2014 F-350 Crew Cab Cassis Cab Dually 6.2L w/4.30
2014 Hyundai Elantra GT
1995 Buick Roadmaster Estate
nikerret is offline   Reply With Quote
Old 08-16-2025, 05:18 AM   #3
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I tracked mine heavily for 3+ years before replacing with the FEA (ZL1 1LE) ones that are not hydraulic PN's 84051643 (L), '44 (R). Eventually replaced the OEM bushing with SPL bushing.
https://www.camaro6.com/forums/showthread.php?t=586653
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 08-16-2025, 08:41 AM   #4
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
I literally wanted to order new arms right now because I got slight play at the driver side wheel.
Just saw this topic and I have since last year this dark hydraulic fluid on the passenger side control arm. I had no clue and thought it was from the engine or coolant residue.
Anyway, I now luckily odered the FEA ones right away.
I noticed all the fluid last year with less than 11800 miles and maybe 4 hours total track time. This durability is a joke. (Suspension was completely untouched and stock at that time)
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, CHE trunnion bushings. Tuned by JRE
SpeZ is offline   Reply With Quote
Old 08-16-2025, 10:05 AM   #5
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
I have about 32 track days on mine (5th year now), with 19K total miles (including off-track) and mine look fine. I wonder if it has anything to do with rumble strips/curbing, as I generally try to stay off of it and only kiss the edges.
How much of the rumble strip curbing are you guys with "early" bushing failure using?
N Camarolina is offline   Reply With Quote
Old 08-16-2025, 10:55 AM   #6
cdb95z28
cdb95z28's Avatar
This has been a known issue for a while on the FE4 cars that are tracked. They'll give up faster with stickier tires. Just go with the ZLE forward (aka radius rod) arms. They are a solid rubber bushing and were/are cheaper than the FE4s. This was the first mod on my car. The FE4 are hydraulic bushings.
"KEEP THE FAITH"-Fbodfather
Old 08-16-2025, 12:50 PM   #7
SpeZ
SpeZ's Avatar
Good mention here, but for me my passenger control arm leaked and the track where I only drive goes clockwise, so the rumble strips are on driver side at all times, except in one turn. Just for short time and sometimes the right wheels drive on the curb too.
But overall, I usually avoided them, but I have to admit theyre really rough.
Old 08-16-2025, 07:52 PM   #8
dpevans
16k miles, have 12 track days so about 60-65 sessions and 8 auto cross days. When they start leaking it whacks out your alignment. Going for SPL parts this winter and will swap over everything next spring. Talking with a GM tech I auto cross with and he said this is a warranty item for the 1LE. I needed a quick repair and wanted both done so I did them myself. I also don't curb it hard but I do use the smooth ones. I have always thought of suspension as wear parts on track cars so it was expected.
Old 08-17-2025, 06:04 AM   #9
carguy55
carguy55's Avatar
The issue with the SPL arms is they don't provide a way to attach the brake cooling ducts. Some people have found their own way to attach them or go without. I like running the CTS-V brake ducts for cooling for track so I went with the FEA arms with SPL bushings.
Old 08-17-2025, 01:48 PM   #10
dpevans
Good point.
Old 08-17-2025, 08:18 PM   #11
N Camarolina
I'm trying to learn here. Why the SPL bushings in the FEA arms rather than the OEM FEA bushings? How easy was it to swap out the bushings?
Old 08-18-2025, 08:28 AM   #12
SpeZ
SpeZ's Avatar
I'd say because the SPL arms have spherical bushings made out of steel for maximum stiffness. Definetly an upgrade. I doubt that the bang for the buck is worth. For myself, I will stick to the FEA for now.
Old 08-18-2025, 03:24 PM   #13
DeuceCam
Drives: LT1
Are the ZLE radius arms the same as the SS or does the ZLE have a harder durometer rubber?
DeuceCam is offline   Reply With Quote
Old 08-18-2025, 05:07 PM   #14
cdb95z28
cdb95z28's Avatar
The FE4 cars (SS 1LE and ZL1), the regular SS (FE3) and the ZLE (FEA) all have different radius rods. The casting is the same but the bushings are all different.
