Old 08-15-2025, 10:33 AM   #1
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Drives: Black 2023 ZL1 A10
Storage question..again
I know this is early(for me anyways). I've been "storing" my car each winter from around Halloween time until Mid to end of May. This will be the 4th time coming up this year. My specific question is, do I NEED or HAVE to disconnect the negative cable from the battery when putting my trickle/maintenance/ tender charger on it during that time span. I've been seeing/reading people doing it BOTH ways with no specific advantage or disadvantage for doing it. I'd rather not if I don't NEED to but it it's not hard TO do it if it's "better" fir the battery/car. I prefer not to do under the hood to the posts due to the set up of my garage. I prefer hooking the tender directly to the battery. It's a finished garage(3rd stall)with a ceiling mounted corner heater which helps in the winter, but obviously freezing cold air comes in each time we go out the double garage until the door closes and the heater catches up again.
Thanks for any and all input!
2023 A10 ZL1 "NYTMARE"
NYTMARE23 is online now   Reply With Quote
Old 08-15-2025, 10:41 AM   #2
MT-SS1LE
Drives: 2023 SS 1LE Sharkskin
I don't disconnect the negative battery cable on mine and have never had an issue. Battery drain would be less if it were disconnected, but that's not an issue if you have a maintainer on it 24/7.
ΜΟΛΩΝ ΛΑΒΕ
MT-SS1LE is offline   Reply With Quote
Old 08-15-2025, 10:58 AM   #3
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Makes sense! Thanks for the input!. I have been disconnecting it each winter but I recently asked myself....do I NEED to do it?...so that's why I posted. Thanks again!
Old 08-15-2025, 11:56 AM   #4
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
With it connected the car is still partially awake. Using low amounts of energy to keep things ready for action. The battery minder inputs more than the car is consuming in that state. With it disconnected the only loss is from just static degradation of the battery alone. The minder will overcome that easier so in theory the amount needed to input over time will be much less. It's not something so dramatic that you will see it in your electric bill but it will be a difference.
With the minder plugged in and not even on a battery it will consume home energy. Pretty close to what a phone charger uses when plugged in but not to a phone. So if you wanted to further reduce consumption. Disconnect the negative cable and on the first of each month put the minder on the battery for the day and remove it at the end of the day. But like i said, it wont be much noticed in the bill.
The downside to disconnecting is your ecm and tcm have to relearn fuel trims, shift patterns, throttle positioning, lots of driving characteristics that you dont realize were there. It will do it naturally and is constantly fine tuning it anyway so it's not that big of a deal.
Old 08-15-2025, 10:52 PM   #5
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Thank you for the information! Appreciate it!
Old 08-15-2025, 11:53 PM   #6
JT6Speed
JT6Speed's Avatar
Drives: 2023 Camaro 1SS M6
Yeah I've never disconnected the terminal on this car, or any other for that matter. I hook it up to the "tap off" under the hood as I like to call it. Either way, as long as you got juice going in all winter, it should fire right up in the spring and roar to life
Black 2023 Camaro 1SS Coupe M6
Ordered: April 2022-----Built: July 2022-----Delivered: September 2022
-Dual-Mode Exhaust (NPP)
-Red Painted Calipers (J6F)
-5 Split Spoke Bright Silver Painted Aluminum Wheels (56W)
-Chrome Camaro Logo Fender Badge
-Second Generation Front Splitter in Satin Black
JT6Speed is online now   Reply With Quote
Old 08-16-2025, 03:29 AM   #7
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Just leave it connected, the tender will way outweigh any minute power being used by the car... Keep it simple...
Old 08-16-2025, 09:35 AM   #8
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Sounds good to me!. That first roar in the spring is something, isn't it!??
Old 08-16-2025, 09:37 AM   #9
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
I definitely like keeping it simple, if possible!. Thanks!
Old 08-16-2025, 10:24 AM   #10
knighti2
knighti2's Avatar
Drives: 2SS M6 Hot Wheels #515
I have used my tender / conditioner on everything from Silverado 1500, 2500, Camaro, Cadillac BW, BMW and a Lexus so far.
It has been on them anywhere from a week to few months. Never disconnected negative terminal and never had an issue. As the Capt says KISS always seems to outweigh any possible negatives I have found 99% of the time.
Rotofab, Soler 87mm ported TB, Kooks headers / green cats, MSD wires, flex fuel
Stock intake (no porting) and stock NPP exhaust.
knighti2 is offline   Reply With Quote
Old 08-16-2025, 11:16 AM   #11
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Sounds good!. Thank you!
