Old 08-13-2025, 03:27 AM   #1
CeesCam
Drives: Mazda 6 GG
Conversion to German standards: head gasket and brakes
Dear friends,
I want to buy a Camaro which was imported into Germany.
(I live in the Netherlands)
Wen imported into Germany, conversion to German standards meant a head gasket conversion with everything that goes with it, as well as larger brakes. I really have no clue as to why you would want te replace the head gasket. Does anyone know this? Is it risky to buy a car that had this type of modification?
Thanks in advance,
Cees Verloop
CeesCam is offline   Reply With Quote
Old 08-13-2025, 03:28 AM   #2
CeesCam
Drives: Mazda 6 GG
This is about the 2017 SS model.
Old 08-13-2025, 08:37 AM   #3
I have never heard of a mandatory head gasket conversion for Germany. GM had European spec Camaros, perhaps they used a different head gasket, but I can't imagine a reason to replace a perfectly good one from the US. Now, is the conversion risky? Depends on who did the job
The larger brakes are a nice touch, try to find out what that actually means, hopefully it's the 6-piston conversion GM used to offer for a cool ~$3000.
Old 08-13-2025, 05:01 PM   #4
DeuceCam
Drives: LT1
The changes might have to do with the materials the components are made of. Kind of like how the California cars require different brakes. Just a guess.
DeuceCam is offline   Reply With Quote
Old 08-13-2025, 06:22 PM   #5
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
Nothing about that makes any sense.
Warrior102 is offline   Reply With Quote
Old 08-15-2025, 11:12 AM   #6
CeesCam
Drives: Mazda 6 GG
This car was imported from Canada. Maximum speed Canadan about 110 km/u.
Cheaper/ thinner materials used. Then, in Gemany no speedlimit. I am told this is the reason why the car needed an update.
Old 08-15-2025, 11:41 AM   #7
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
That doesn't make sense either, that would require an entire system retooling to accommodate making engines with lower standard parts. That would cost the same as the engines already made. 110km regulations would just be done in the software.
Leaded gas vs unleaded would be the only reason i could see different parts used. Exhaust valve materials and catalytic converters would be a stretch on hardware differences.
Now maybe, the heads were removed and new gaskets installed for annual inspection of internal engine components, similar to how Japan does. Or did. Im not sure if that's still the case. It was why we used to be able to get so many low milage jdm engines back in the day.
bishopts is online now   Reply With Quote
Old 08-15-2025, 05:02 PM   #8
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
A thicker head gasket = lower compression ratio. Is there less availability of adequate octane gasoline there? I think not, so most likely it was for an inspection and the larger brakes may have simply been a request from the previous owner? I can't imagine the standard SS brakes would be considered inadequate even for the autobahn.
Ventmaster is offline   Reply With Quote
Old 08-15-2025, 09:03 PM   #9
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
Do you mean headlight conversion? I have no idea about an engine part...octane is higher in Germany than US...
Tim M is online now   Reply With Quote
Old 08-15-2025, 10:22 PM   #10
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
Canada goes up to 120 km/h speed limits. It doesn't make sense they'd go through the effort of putting different parts in for such a small difference in top posted speed limits.
speedyink1 is offline   Reply With Quote
Old 08-17-2025, 05:57 AM   #11
CeesCam
Drives: Mazda 6 GG
Ok, I also think it makes no sense for a car maker to make a difference in thicknees of the headgasket depending on speedlimits in particular countries.
This is the more elaborate text from the salesperson:
This is the case in the US, as well as in Kannada, and perhaps the rest of the world, where there are speed limits, so it's perfectly sufficient for cars to be equipped with a thinner head gasket and "less durable materials."
This means that at speeds of 100 km/h -130 km/h, it's not absolutely necessary to use expensive materials.
But since we drive cars in Germany, and we don't have a speed limit, we "can" drive faster.
We need materials that are thicker or have better strength so the engine doesn't break.
I got the Camaro from Kannada; in Canada ���� you're only allowed to drive 110 km/h, and anyone who drives faster can lose their car or end up in jail.
That's why cheaper materials are used in such cars.
If you hit the gas here and drive 270-300 km/h, it would destroy the head gasket and all the cheap components.
That's why I modified or converted my Camaro completely legally.
Parts like the head gasket, etc.,
are simply replaced with stronger materials.
Old 08-17-2025, 06:14 AM   #12
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
Big cap. No one ever would replace the head gasket, except it went bad.
It prolly overheated once, thats the reasons.
Makes no sense, that they used bad gaskets for canada fellas, cuz they got a speed limit. lol.
If it came first from canada -> germany then it should have a km/h speedo if its a canada model.
Watch out for salvage model here in europe. Some of them ain't bad, but many are fixed cheaply.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, CHE trunnion bushings. Tuned by JRE
SpeZ is online now   Reply With Quote
Old 08-17-2025, 06:40 AM   #13
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
ariZona28 is online now   Reply With Quote
Old 08-17-2025, 12:27 PM   #14
speedyink1
speedyink1's Avatar
Yeah, total salesman scam. This would mean:
-Gm took the time/money to put cheaper parts into a 455HP car shipped to just Canada because there's a 16km/h difference in posted top speeds.
-They also told people they could go on track with this cheap head gasket because they know everyone drives on the track extremely gently.
-There would be multiple reports of head gasket failures for track users/people who "drive it like they stole it" (this forum is littered with these kinds of reports, right?)
Importer is clearly taking advantage and charging false fees. I'd be surprised if they even touch the head gasket/brakes, but charge you for it anyway.
