Old 08-04-2025, 10:37 AM   #1
jclift
jclift's Avatar
Drives: 2022 Ram TRX
Cam Swap without Removing Heads
Has anyone successfully swapped a cam without removing the heads on an LT4 motor?
jclift is offline   Reply With Quote
Old 08-04-2025, 11:17 AM   #2
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
If sticking to a DOD capable cam then yeah it's possible to do a cam swap without removing heads. If you are deleting the DOD setup then heads have to come off. The question here, is if the engine is out and opened up, why would you not remove the heads to do a DOD delete? That hardware has a known track record for premature failures.
758 HP/ 804 TQ
Old 08-04-2025, 11:46 AM   #3
Mark R
Drives: 2018 ZL-1
What is DOD?
Old 08-04-2025, 11:58 AM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by Mark R View Post
What is DOD?
Displacement On Demand. Aka Active Fuel Management “AFM”.
Old 08-04-2025, 12:49 PM   #5
Mark R
Drives: 2018 ZL-1
I didn't think the LT-4 had that, only the naturally aspirated v-8's.
Old 08-04-2025, 01:09 PM   #6
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
It still has the DOD lifters even though some LT4 vehicles don't have the featured enabled.
GM Gen V Calibrator
Old 08-04-2025, 01:09 PM   #7
Joshinator99
Moderator
Believe the AFM lifters are still in the engine though even though AFM is not active on that engine.
Edit: Megahurtz beat me to the punch.
Old 08-04-2025, 01:37 PM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
LT OHV engines (L83,L84,L86,L87,LT1,LT2,LT4) have AFM/DOD engine internals. Only the L8T and LT5 do not. Some vehicles that are LT engine equipped with AFM/DOD hardware have the feature disabled in the ECM.
Old 08-04-2025, 01:41 PM   #9
ZLRob
Super Stock
ZLRob's Avatar
Yeah, so the story with the LT4 is that the hardware for it is in place, lifters, VLOM integrated into the valley, and the cam as well, but anything required to activate it is disabled within the PCM parameters from the factory... I highlight the problem again though, because the hardware is in place (particularly the lifters) there is a HIGH chance of one or more of them collapsing under normal operation because of how complex and cheaply built they are. If you are going to remove DOD lifters though you need to change the cam for it as well.
758 HP/ 804 TQ
Old 08-04-2025, 02:38 PM   #10
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Simple answer is YES, you can... The better question might be (should I)
How many miles on the car?
Old 08-09-2025, 05:22 PM   #11
L98 Z28
L98 Z28's Avatar
Drives: 2017 ZL1 6spd Convertible NFG
All ZL1 LT4s have AFM disabled? My manual ZL1 does not have AFM (is it just disabled?), but I thought the 10-spd automatics had AFM. My GF's (8-spd automatic) CTS-V LT4 has AFM enabled and I don't like it.
L98 Z28 is offline   Reply With Quote
Old 08-14-2025, 04:09 PM   #12
No AFM on my 2024 ZL1 auto
Old 08-14-2025, 04:14 PM   #13
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Exactly what these guys have said. No ZL1's have it enabled, but unfortunately all the hardware is physically there in the motor. The only performance vehicles that don't have the hardware are the ZR1 and the Escalade V.
Mods being installed-
Old 08-17-2025, 04:54 PM   #14
L78toLT1
L78toLT1's Avatar
Is the simple answer really YES? I've had my motor apart more times than I can count, and I don't see how it would be possible. I suppose if you're swapping in another DOD cam, it may be possible to remove the rockers and pushrods and raise the lifters one at a time with a magnet while working the new cam in. I don't think you can remove the lifters without removing the heads, and assuming that you can't, i cannot envision a scenario that would involve replacing a cam and retaining the oem dod lifters
Baby Blue
