Old 08-02-2025, 01:56 AM   #1
2018zl1-1le
Drives: Zl1 Camaro
Tires spinning at 70 mph
Is it normal for me to spin the tires when I’m doing 70 mph and drop it into forth gear and floor it then it spins and traction control comes on in my zl1 1le
If so how to get it to grab right away also running ps4 tires have all the links from SPL
2018 Zl1 1le 6speed
2” Kooks headers ,green cats full exhaust
JLT intake, BTR Stage 2 cam,Mighty Mouse catch can
Innovations west damper 9.25” lower
107mm throttle body, Mpi lid, flex fuel
Full SPL rear suspension, DSX twin intank pumps
2018zl1-1le is offline   Reply With Quote
Old 08-02-2025, 05:31 AM   #2
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Same here, root cause is the stiff suspension on cold tires.
Also you may want to change your diff oil if its been a while.
you have a couple options if you want the car to move:
buy new rear tires every month
run drag radials
use tire warmers
do a burnout everytime you leave the house
if you dont track the car you could swap out the coilovers and rear shocks to something with a lower spring rate that will allow for weight transfer.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 08-02-2025, 06:22 AM   #3
2018zl1-1le
Drives: Zl1 Camaro
Could I just replace rear springs would that help? Or be a good option?
2018 Zl1 1le 6speed
Old 08-02-2025, 07:17 AM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
That’s not going to help if you’re doing 70 when you floor it IMO. Need stickier tires. NT555R2 is probably your best bet. R888R is good too but louder.
Old 08-02-2025, 09:08 AM   #5
nighttowl
nighttowl's Avatar
you could but the the shocks are valved for the stiff springs.
Old 08-02-2025, 09:10 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Agree....
Old 08-02-2025, 05:16 PM   #7
2018zl1-1le
Drives: Zl1 Camaro
Thanks thinking of going to the nittos
2018 Zl1 1le 6speed
Old 08-02-2025, 05:26 PM   #8
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
My Nitto 555R2's did great for me... But I was still spinning in 4th if I nailed WOT. I then went with Mickey Thompson ET Street R's, and WOW! I know now what it's like to have tires that actually grip and bite!
But, back to the Nitto's, they were great tires, and no where near as loud road noise as I hear others say the Toyo R888R's are.
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 08-02-2025, 06:30 PM   #9
clj94104
Drives: Camaro ZL1
R888R won’t spin in that scenario. They get a lot of hate, but they’re really good for rolls lol
clj94104 is offline   Reply With Quote
Old 08-02-2025, 06:48 PM   #10
Joshinator99
Moderator
Agreed, I run them as well in street trim and their performance has been solid. But looking to try the NT555R2 next time I buy street tires. At 400 miles a year they tend to last a while lmao!
Old 08-04-2025, 12:22 AM   #11
AZIROC
Drives: '86 IROC-Z '18 ZL1
M/T ET Street S/S.
888r's if you like sounding like a Wrangler on mud tires
Old 08-04-2025, 09:37 PM   #12
2018zl1-1le
Drives: Zl1 Camaro
I do pretty much daily drive it in summer months. So I’m thinking the nittos are slightly better in days I get caught in the rain
2018 Zl1 1le 6speed
Old 08-04-2025, 10:18 PM   #13
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
May need tires with wider operating range... PS4S ftw.
ing for grip.
http://www.motorsportsne.com/
Old 08-04-2025, 11:20 PM   #14
PowerDemon
PowerDemon's Avatar
Drives: Camaro ZL1, Golf R
Any tire besides a dedicated radial/DOT slick is going to struggle if you’re hammering it on a 650whp+ blower car. The simple physics of trying to instantly thrust a 4000lb car forward with that much torque means it’s going to knock the tires off in almost every instance. I do not believe that on these cars there’s many suspension options to increase grip once you’ve done all the suspension arms in the rear. Unless of course you want to switch to MRC or Viking coilovers.
In terms of tires the PS4 sucks at anything other than being an OK summer performance tire that lasts, is comfortable, and quiet. My Goodyear Supercar 3s hook up way better than my PS4s did (when they’re hot) and give far better steering feel and lateral performance. IMO you’ll want to ditch the PS4s ASAP and pick up at a minimum a GYSC3, or even better a Toyo R888, or Nitto NT555 RII. Just remember, even with those tires there’s a good chance you’ll spin a bit if you hammer it. It’s best to roll into it if you can. These cars have a lot of torque and are quite heavy as I previously mentioned. Good luck
’22 ZL1 Riverside Blue 6MT
’17 Golf R Limestone Grey DSG
PowerDemon is offline   Reply With Quote
