![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Magnuson 2650 pulley combo and hp/boost?
going to the boost side. Got a 2650 coming. built shorblock. i will have enough fuel to run full e85 up to about 900 rwhp. Full DI no port
I have asked a couple people about combos and just wanted a few more opinions before i buy the kit. Im doing the 10 rib kit with lt5 tensioner. I was told to go with the 9.2 15% lower and 85 mm 6% upper. To get me around ~17 lbs and ~850 rwhp range -Magnuson 2650 -Stock lt1 heads with lt4 gaskets -Built short block with 11.5 compression -stage 2 cam (dont know specs atm but its medium size still can use stock TC, 6800 or so shift points) - full catless exhaust with 2 inch headers -103 tb and 5 inch intake -full e85 all DI Like i said just looking for the pulley combo to be 850 rwhp range on full e85. Can do more on a mix etc but i think that should be plenty for now. Raceweight will be 35-3600 with driver after adding blower components. Car was under 3400 with driver NA. thanks for the insight |
In to hear feedback on this. Nice sounding build!
Camaro SS - (almost) FBO/E85: Tuned by Snackbar Tuning/21st Century Muscle Cars
With that compression I bet you hit that power goal with 14-15psi. I would probably start with the 90mm upper. That point and half compression makes up for 2-3 psi compared to a stock compression LT4.
Far as cooling, the Magnuson stuff is plenty sufficient combined with the expansion tank.
#4 | |
First time going boost so I appreciate any input |
Btw king I messaged you back but said your box is full
I just cleared it out.
#7 | |
Moderator
#8 | |
I haven’t bought the short block yet. I could easily back off the compression. I just didn’t see it as necessary under 1000 hp on my build running full e85. But I could be missing something? I know compression can be good as well to a point. I’m coming from na my knowledge is limited on boost |
#9 | |
Moderator
#10 |
I’ve got e85 all around me that typically is at 76-79. I’m coming from a 14.1 compression 630 rwhp na setup.
#11 |
Petro-sexual
Are you from LS1tech?
#12 |
Yes
#13 |
![]() Drives: 2023 Riverside Blue 2SS Join Date: Sep 2022
What fuel upgrades do you have? Im trying to get to the point where I can comfortably run full E85 at around 700whp. I was thinking LT4 fuel system with my 32% Cam lobe would be enough.
#14 | |
With full e85 youll need the aux pump for low side. dsx 320. Those support 1000rwhp range. There are other options as well. I think your in tank pump is already lt4 style being a new SS. But im not certain. I think the lt4 injectors and hpfp will support 700 rw on full e85. More on a mix. mine (lt4 hpfp and injectors) are going to be for sale very soon. About 5000 miles. If you are interested. |
