Craig
Drives: 2019 ZL1 1LE Join Date: Jan 2019
Thermostat Cracked?
I’ve been smelling coolant after my built and finally noticed just under the little tube at the top of the thermostat there’s a small line of coolant. So I’ve looked into the DMS Billet Housing but it uses a LS3 style Stat, I already have a Katech 160 stat that was added during my build but I guess it won’t swap in.. has anyone changed to this stat? Also was told by my tuner that they vacuum filled the system for no air, I do have a Cordes Expansion tank would that not self bleed the system and prevent the air lock?
#2 | |
Moderator
The Cordes expansion tank is likely for your intercooler circuit and separate from your regular cooling system.
#3 | |
Craig
#4 | |
Moderator
You don’t HAVE to vacuum purge the cooling system. It actually does a great job of working air out of the system itself. I’ve done it both ways. Vacuum method is great but I did it the “regular” this last time and it was pretty easy.
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
"KEEP THE FAITH"-Fbodfather |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
The service manual shows vacuum fill as well as static fill. Like Josh said, both can be done with success. I've only done the static fill when I drained the coolant and didn't have issues. Just keep adding coolant with the top cap off and the bottom chamber cover open as you run the car. Can work out the bubbles faster by squeezing the hoses.
Check out my youtube channel
https://www.youtube.com/@evans.educa...ocxUzC1ferqeg8 Full SPL suspension / Ported blower / NW 103mm / Rotofab BG / 2" Headers / Ported heads / Upgraded Valvetrain w/ DOD delete / Custom 38% Cam / C7.R Timing chain / Katech Oil pump / BMR motor mounts and chassis braces / Katech 174* Thermostat / Pierburg Supercharger coolant pump / PLM HX / JMS voltage booster / ATI Damper w/ 8.6 Lower / MM Mild catch can / ADM Resevoir / soon to come... Rebuilt Engine / XDI +30% injectors / PWR Oil cooler setup / GMS Hood bracket 760 Whp / 700 Wtq E50 |
#7 |
![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
I kept the OEM housing and added a thermostat belt guard. I've refilled the cooling system several times and never vacuumed it. Just topped it off on first few drives.
#8 |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
I run a DMS with a factory Vette LS3 186* t stat. It has never caused me a single issue since I installed it a year and a half ago or so.
758 HP/ 804 TQ Last edited by ZLRob; 08-10-2025 at 11:14 AM. |
