Craig
Drives: 2019 ZL1 1LE Join Date: Jan 2019
Camshaft Position Sensor
Has anyone replaced a camshaft position sensor? I keep getting P0340 after a recent stage 4 build so I’m going to try a new sensor. Just trying to see if it’s an easy replacement that I’ll be able to manage at home / where the sensor is located?
Thanks!
![]() Drives: Chevrolet ZL1 Join Date: Jul 2020
I had the same code when my oil pump was installed. Found out that the male and female end of the connectors had coolant in it even though the connections were protected.
I blew it out the coolant with some air and QD electronic cleaner. Cleaned it out about three times to make sure. Cleared the code and it was fine after that. I did buy a sensor just in case, so now I have that sitting in my spare parts bin. |
#3 | |
Craig
I got that from above and the connector with the red tab that was on the bottom right.
Craig
I just grabbed a sensor too but I’ll try cleaning this connector first, grabbed a can of compressed air as I don’t have anything else lol. Did you just have to remove the intake elbow to access or or anything else need to come off?
I did remove my intake elbow to make things easier when I had done mine.
#7 |
Craig
I got my elbow off but seems like I need the belt off just to get to the sensor and then gotta try and get to the connector after lol
#8 |
Sorry I forgot about the belt. lol Well since your looking at your belt, how is the condition? I bought a Green belt and installed it and kept my stock one in my trunk for just in case.
