![]() Drives: 95' camaro Join Date: Feb 2015
Thoughts on this 15" Conversion
I have been considering doing the 15" conversion on a '16 2SS. While I know the conversion isn't considered worth it unless you are making big power, since I don't exactly know my end-goal power levels, I am considering it since I am starting from scratch. I put together a list based on the YT video by SLOW.VERT and this thread: Diy 15” conversion.
Thoughts? Suggestions? Note: this is coming from a fresh start, no 15" or 17" wheels currently owned, so everything is still TBD. |
Moderator
If I had to do it all over again I would have just stayed with 17” setup out back. The 15” barrel is too tight to the calipers so you can’t road force balance the setup. My 17” setup was smooth as silk down the track…the 15” setup is much less stable at the top end IMO.
