Old 07-17-2025, 07:58 AM   #1
clg82
Drives: 2020 Camaro ZL1
Odd starting issue(?) maybe
Hey everyone that is running full ethanol. From some research I had already done before going full ethanol, I read that it can be sort of a "slow crank" start during a cold start. What I find odd is, when I do "remote start" on cold start, the car cranks right up. What's the difference between the two? What is the car doing differently that one is different than the other. Anyone else notice this? Just an odd quirk I noticed.
Old 07-17-2025, 08:09 AM   #2
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
Switch over to a lithium battery. I had that issue with an AGM as well. I think these engines just require more "oomph" than traditional batteries the size that is allowable are capable of is all. These cars are definitely power hungry anyway.
758 HP/ 804 TQ
Old 07-17-2025, 08:10 AM   #3
clg82
Hmm interesting thought, but it doesn't answer the question as to why when I remote start it doesn't have the same issue as opposed to just pushing the ignition start button.
Old 07-17-2025, 08:27 AM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
The only difference I know of is: the BCM doesn't have the car all lit up when you use remote start. But it sure will be when you get in through the door. How much power is that? Don't know, probably a few amps.
I'd check the battery terminals. If you're feeling froggy and have a meter, do a voltage drop test on the and power wiring from the battery to the starter and back, including the grounds.
Also probably won't hurt to throw on a battery tender for a couple days, the AGM might just (or also) be low on charge.
Old 07-17-2025, 08:36 AM   #5
ZLRob
Super Stock
ZLRob's Avatar
My only educated assumption would be that the rest of the vehicle does not need to be as energized to remote start as the vehicle is when you are turning it on yourself which enables other control modules and devices.
Mine was the same way. It was lazy starting manually but remote start was pretty quick cranking. It doesn't exhibit any of those symptoms anymore since I switched a year/ a year and a half ago.
758 HP/ 804 TQ
Old 07-17-2025, 08:41 AM   #6
clg82
Thanks fellas, I also thought maybe the remote start feature "primes" the fuel pump and than starts, when the push start might not. Just throwing ideas out there. But it does make sense that when seated in the car and unlocked via remote or handle without remote starting, it may turn EVERYTHING on as opposed to the remote start.
Old 07-17-2025, 08:52 AM   #7
ZLRob
Super Stock
ZLRob's Avatar
These cars are so power hungry that traditional battery tech is not really up to snuff most of the time unless you can find an appropriately sized battery with more CCA's and higher AH than the OE one. That's why I made the switch on mine and haven't looked back since. Whether remote start or push button start, it always cranks over very quickly and never gives me an issue now.
Hopefully this helps!
758 HP/ 804 TQ
Old 07-17-2025, 09:04 AM   #8
clg82
Roger that! Damn those lithium ion anti gravity batteries are expensive!!!!! Than again what isn't in this stage of modifications
Old 07-17-2025, 09:14 AM   #9
ZLRob
Super Stock
ZLRob's Avatar
Hell yeah it is dude! EVERYTHING gets costly this far up in the build process.
I got a good, cheaper solution though, for the battery if you want one. TONS cheaper than anti gravity and just as reliable. Seriously, I run this one in mine and it's been entirely problem free except for one time that I drained it down to protection mode on accident due to leaving a high power relay for my secondary fuel pump energized all day and night for two days.
https://www.ebay.com/itm/29500135464...kAAOSwzeFgnBpK
758 HP/ 804 TQ
Old 07-17-2025, 09:43 AM   #10
calypso50kid
Drives: 2018 zle, 03 cobra, 92 mustang lx
I have a long crank hot start that happens if i stop somewhere for a few minutes and then go to crank again, Ive noticed if if i delay the starter lockout that i have for security for a few seconds after i hit the start button it starts fine, im guessing it needs a longer prime when hot thats the only thing that would make sense.
Owner and driver of the worlds fastest naturally aspirated drag radial car. Hays Consulting and Performance
4.58@151 BBC powered 585 ci 9000+ rpm
https://youtu.be/wSz2OedlNSI?si=SnPoqreXFQ7NLYX8
2018 ZL1 1LE 416ci LME long block, 2650, reflex port injection, full e85, tick performance tr6060, monster triple disc, DSS drive shaft, g force axles.
calypso50kid is offline   Reply With Quote
Old 07-17-2025, 10:20 AM   #11
clg82
Hmm interesting, I am not sure there is a difference in when the car is hot vs cold for me. I will have to test that theory this weekend. I generally only start the car from the inside in the garage and remote start outside of the house.
Old 07-17-2025, 10:41 AM   #12
ctrlz
If you're feeling froggy and have a meter...
Froggy, huh?
Anyway, pop the hood. Measure battery voltage with the car asleep. Then open driver's door to wake the car and measure voltage.
I'm guessing 2020 battery may be dropping voltage even under slight load.
Old 07-17-2025, 11:10 AM   #13
Gunkk
Gunkk's Avatar
Yeah that's what I'm thinking. Our cars don't behave well with low battery voltage. A day or two on a tender might save the AGM from premature replacement.
Learned this one the hard way.
Old 07-17-2025, 11:25 AM   #14
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
I had this issue after picking my car up from Katech this past spring. I even sent an email to Mike mentioned I noticed the had to crank over like 5 to 6 seconds before starting. Mike told me to check my battery voltage, and it was low. I charged the battery but still had the issue, but when checking the voltage it was still low. I put up with that for a few weeks and the battery finally totally died. Got a new battery and the car started perfectly like normal and ran fine!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
