Old 07-17-2025, 01:07 AM   #1
Camaro ZL124
Drives: Chevy camaro zl1
2650 magnuson supercharger
I was cleaning my engine and I think I accidentally got some foam engine cleaner on my air filter and now my supercharger is making a weird noise. I’m not sure what to do next. Im Thinking I might need to either buy new bearings and a supercharger coupler. I do t even know where to begin with this. And advice?
Link to video: https://youtube.com/shorts/bW11a-JJ6...VP3SXXinbUoaSY
Camaro ZL124 is offline   Reply With Quote
Old 07-17-2025, 07:41 AM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by Camaro ZL124 View Post
I was cleaning my engine and I think I accidentally got some foam engine cleaner on my air filter and now my supercharger is making a weird noise. I’m not sure what to do next. I. Thinking I might need to either buy new bearings and a supercharger coupler. I do t even know where to begin with this. And advice?
Unless you directly sprayed the air filter with a decent amount of liquid I would doubt that was the case. Post up a video clip of the engine running with the blower noise when you get a chance.
Old 07-17-2025, 08:06 AM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Bearings are in a sealed gear case at the back of the blower.
'20 ZL1 Black "Fury"
radz28 is online now   Reply With Quote
Old 07-17-2025, 09:35 PM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
That's coincidental...no way that would cause a bearing failure.
Old 07-17-2025, 09:37 PM   #5
Joshinator99
Moderator
Totally agree
Old 07-17-2025, 10:58 PM   #6
Camaro ZL124
I just posted a video. So I took the supercharger belt off and it still
Made the noise. So it’s not the supercharger. I started to think back and the noise started after I added E85. When I first added the e85 the flex fuel sensor adjusted it to e50 driving for like 2 minutes it went down to E42. Now I’m thinking bad fuel maybe or bad injector not sure.
Old 07-18-2025, 01:06 AM   #7
Camaro ZL124
Just added video please view if you have the time
Old 07-18-2025, 09:13 AM   #8
tbair64
tbair64's Avatar
Drives: 2022 Camaro LT1
more than likely you got the engine cleaner on the belt. And has dried the belt out. to verify spray a little lubricate on the belt W/D 40 would be fine just a small amount while the engine is running. if the noise changes or goes away that's your problem. change the belt.
tbair64 is offline   Reply With Quote
