Old 07-16-2025, 10:42 PM   #1
RedHotSS17
RedHotSS17's Avatar
Drives: 2017 Camaro Red Hot 2SS
Estimated HP After Mods/Tune?
I currently have a 2017 2SS, I installed a KN 63 Series CAI, Brisk Racing Plugs, and the AWE Touring Axle Back. The tuner has 2 Inch speed engineering catless headers and an X-Pipe. After tuning how much HP should I expect?
RedHotSS17 is offline   Reply With Quote
Old 07-17-2025, 02:20 AM   #2
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
460 crank hp
Old 07-17-2025, 07:13 AM   #3
bishopts
bishopts's Avatar
If you have a manual trans i can send you my tune file. I have similar mods, except that i can also run e85
Old 07-17-2025, 07:25 AM   #4
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
+20-25rwhp
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 07-17-2025, 08:25 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Probably not much since the K&N actually loses power vs stock... the plugs and axle back gain nothing either. So 15-20whp.
All of the basic bolt-on stuff has been laid out and made extremely easy to follow.
Ported stock IM/TB 15whp(not a popular option anymore since the LT2 came out). LT2 Manifold swap and 95tb 20-25whp.
Flex sensor- E85 20-25whp
Catless headers 20-25whp
Rotofab CAI 10whp with all the mods above.
Old 07-22-2025, 07:23 PM   #6
p47dman
Drives: 2024 Camaro 1SS
What examples might you have that the K&N loses power? I have this on my car, not that I think I gained anything, but I am sure that I did not lose HP.
p47dman is offline   Reply With Quote
Old 07-22-2025, 08:55 PM   #7
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Unless you have data logs to back up your claim, King is usually spot on with this stuff since he tunes them FYI… I believe the K&N tube diameter is smaller than stock if memory serves.
Old 07-22-2025, 11:20 PM   #8
KingLT1
KingLT1's Avatar
Someone showed a dyno a while back where it lost like -3whp on the stock tune because the tube diameter is smaller. After tuning it's a break even / slight gain over stock. Google will provide more examples.
Old 07-23-2025, 06:29 AM   #9
p47dman
Thanks KingLT1. Going to measure mine now.
Old 07-23-2025, 10:29 AM   #10
p47dman
There is a slight difference in ID. Although the OEM tube has an expansion joint
right after the inlet that I believe would disturb airflow.
Old 07-23-2025, 07:44 PM   #11
ALMN
ALMN's Avatar
Drives: 2SS 1LE M6, Palisade Calligraphy
Pump gas tune alone 91-93 octane you are looking at 15-20 whp. With 2 inch headers and tune probably 30 to 35 whp and torque. I advise you to add flex fuel kit as well so on E you can get another 10 to 15 whp and torque.
ALMN is offline   Reply With Quote
Old 07-23-2025, 07:54 PM   #12
Joshinator99
Moderator
Negative my friend. There is NO gain on a pump gas only tune on a stock SS. King’s numbers above are on the money.
Old 07-25-2025, 06:56 AM   #13
ALMN
ALMN's Avatar
I m pretty positive. Here is a tune only camaro ss on 93 octane by Livernois.
https://youtu.be/Tu40eacO3iA?si=1LEUYzltwlm4PGQw
Old 07-25-2025, 08:24 AM   #14
KingLT1
KingLT1's Avatar
I am not going to get into a big pissin match over stock 93 tunes and K&N intakes but I know a few "good tuners" out there that have shared a lot of info with me over the years and none of them see that kind of power gain tune only on 93. The guys I trust see 8-10whp. I have been tuning since 2014 and I don't honestly believe there is that kind of power to be gained either. These engines come aggressively timed from the factory...they are not rich and the intake, exhaust flow really well (enough to support 500bhp easy).
You can make a dyno read anything. Make the stock pull heat soaked, then make the "tune only 93" pull cold, and voila...there is your big gain.
