![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
Front suspension Height is different
Hello,
I tried Google with no good answers. 2018 ZL1 with magnetic ride suspension. I don't know that I had realize before but my suspension height in the front is about 1/2 in higher on the passenger side. Is this normal? My car was recently aligned but I don't see how the alignment would mess with the suspension height. What should I check for? Anything to worry about? Driver front and both rear tires have the same distance from the top of the tire to the fender lip.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Adding front negative camber will reduce the front ride height. Did you get a sheet with your final alignment #s??
These cars are not perfectly symmetrical on ride heights. There is some variance.
"KEEP THE FAITH"-Fbodfather |
#3 | |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
#4 | |
It was around -1.5 F before
wonder if aftermarket lowering springs would have the same issue or if they will be level all around.
![]() ![]() Drives: 2020 SS 1LE Join Date: Aug 2020
You don’t have the temporary shipping blocks in there, right?
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
It could be but you'd really have to be a blind monkey on an alignment machine working camber and not see an orange block in there but i wouldn't put it past them.
