![]() Drives: 2023 Rapid Blue 2ss Join Date: Oct 2022
ARP Header Bolts Wet Torque Spec
I recently installed headers and I definitely have a leak where they bolt to the heads. I used ARP Header bolts except for one OEM bolt on each side because the ARP wouldn't start to thread in properly in those holes. I applied ARP antisieze to all bolts and I've read on here that 17 ft lbs seems to be the torque spec everyone uses but I only torqued to 12.5 ish ft lbs to account for the antisieze and I'm scared to go much tighter. For those of you running ss bolts and antisieze what did you torque them to?
![]() Drives: 2022 ZL1 Join Date: Sep 2024
I didn’t use ARP, but did use the stage 8 locking bolts that came with my headers. Torqued them to 20 ft/lbs, and not a problem since install. (They are stainless and I used anti seize)
2022 ZL1 M6 Coupe
![]() Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
I used stage 8 locking bolts on speed engineering headers no leaks after 1 year no problem with install at all
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake |
Thanks guys. Torqued them down to 17 ft lbs cause it's as far as my torque wrench goes and no more leaks
#5 | |
Moderator
