Old 07-09-2025, 08:41 AM   #1
Tibby ZL1
Tibby ZL1's Avatar
Drives: 1968 and 2023 Camaros
ZL-1 Tire Pressure
I took my ZL-1 to the dealer for the BCM recall. When I got it back I had a low pressure tire warning. I checked my pressures and they were all within 1 or 2 psi of 32 PSI which is what is on the sticker inside the door. Just this morning, I received my July diagnostics report via e-mail and it said, " Our diagnostic check shows that your tire pressure requires immediate attention. Improper tire pressure can compromise vehicle safety and decrease fuel economy. Please see vehicle maintenance for details on resolving this issue. ", " Recommended
49 psi Front | 49 psi Rear ".
Has GM changed the recommended settings different than what is in the door sticker? Has anyone else had this happen to them after the BCM recall?
I did do a search for tire pressure and nothing came up.
Alan Tibbetts (Formerly ZL1 TIBS)
Aston, PA
2023 ZL-1 Daily driver
1968 Camaro LS408 T56 swap
Tibby ZL1 is offline   Reply With Quote
Old 07-09-2025, 09:02 AM   #2
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
Summer I run 30/31 cold.
I'll run 33/34 when the temps get cool (<50).
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 07-09-2025, 12:01 PM   #3
This is nonsense, do NOT inflate your tires to 49 psi no matter what.
The typical street car tire has a max burst pressure of 50-51 psi, so if you put 49 psi into them cold and gain an extra 3-4 psi as the tire heats up, you'll run north of the tire's factory spec.
AFAIK the recommended cold tire pressure is still 32/32 for wide tires (SS 1LE, ZL1, ZL1 1LE) and 35/35 for the runflats on the SS / LT.
Old 07-09-2025, 12:20 PM   #4
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
yes it'2 32/32...I lol'd at 49.
Old 07-09-2025, 01:43 PM   #5
Tibby ZL1
Tibby ZL1's Avatar
Yes, I think the dealership did something wrong when they reflashed my BCM. It is going back Friday for the fuel line TSB so I will have them correct the tire pressure warning then.
Aston, PA
Old 07-10-2025, 05:38 AM   #6
Curr
Curr's Avatar
Why wouldn't you just air them down before you drive the car?
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Old 07-10-2025, 05:59 AM   #7
Tibby ZL1
Tibby ZL1's Avatar
Curr, if you look at my first post all of my tires are and always have been within 1 or 2 psi of 32. I never considered raising them to 49 psi. I was just trying to see if anyone else had the same issue when they had their BCM recall taken care of or if there was some new pressure requirement (Which I highly doubted).
Thank you to all who commented.
Aston, PA
Old 07-10-2025, 06:00 AM   #8
Tibby ZL1
Tibby ZL1's Avatar
Yes, I did as well.
Aston, PA
Old 07-10-2025, 12:43 PM   #9
JSH
JSH's Avatar
Drives: '20 ZLE
32/32
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 07-10-2025, 03:44 PM   #10
IMCWORTH
IMCWORTH's Avatar
Drives: 2023 Camaro Convertible ZL1 A10
28 or 29 cold all the way around for me not to exceed 35/35 Hot
I only use my car for spirited driving on the weekends
otherwise it sits in the garage
IMCWORTH is offline   Reply With Quote
Old 07-25-2025, 10:29 PM   #11
IMCWORTH
IMCWORTH's Avatar
I found this on page 270 Owners Manual
High Speed Operation Inflation Pressures
Tire Size Cold Inflation Pressure kPa (psi)
245/40ZR20 (95Y) 280 kPa (41 psi)
275/35ZR20 (98Y) 280 kPa (41 psi)
285/30ZR20 (95Y) 300 kPa (44 psi)
305/30ZR20 (99Y) 300 kPa (44 psi)
Old 07-25-2025, 11:25 PM   #12
As per the same manual, "high speed operation" means 100 mph or above sustained, ie multi-mile top speed runs lasting several minutes.
People wouldn't use these crazy high cold pressures even on a road course, but hopefully they will chime in and confirm.
Old 07-26-2025, 05:23 PM   #13
TurboC3
TurboC3's Avatar
Drives: 23 ZL1, 08 C6 vert, 70 Skylark GSX
For the factory SC3s 37-38psi, hot is the sweet spot for track days. Any higher, they get "greasy" on track. Street 32-34psi would be fine IMHO.
TurboC3 is offline   Reply With Quote
Old 07-26-2025, 06:48 PM   #14
Originally Posted by TurboC3 View Post
For the factory SC3s 37-38psi, hot is the sweet spot for track days. Any higher, they get "greasy" on track. Street 32-44psi would be fine IMHO.
Please correct this typo, or people will get very confused
