Old 06-30-2025, 04:20 PM   #1
SuperslowSS
Drives: '19 Chevy Camaro 1ss
PCV Hose help
Hello all,
I’ve been trying to replace the passenger side PCV line running to the PCV oil separator. The issue is I can’t find the part number, neither I or any dealership parts department I’ve gone to has been able to. It’s a ‘19 SS. Any advice? The part numbers I got were 12670879 and12681424
SuperslowSS is offline   Reply With Quote
Old 07-03-2025, 09:29 PM   #2
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Ac delco 12687311 looks like it might be the correct one. Found it at autozone
Check out my youtube channel
https://www.youtube.com/@evans.educa...ocxUzC1ferqeg8
Full SPL suspension / Ported blower / NW 103mm / Rotofab BG / 2" Headers / Ported heads / Upgraded Valvetrain w/ DOD delete / Custom 38% Cam / C7.R Timing chain / Katech Oil pump / BMR motor mounts and chassis braces / Katech 174* Thermostat / Pierburg Supercharger coolant pump / PLM HX / JMS voltage booster / ATI Damper w/ 8.6 Lower / MM Mild catch can / ADM Resevoir / soon to come...
Rebuilt Engine / XDI +30% injectors / PWR Oil cooler setup / GMS Hood bracket
760 Whp / 700 Wtq E50
Old 07-06-2025, 02:40 PM   #3
SuperslowSS
We thought it was but that’s the one that goes over to the drivers side. Thank you though, I still haven’t been able to find it
hoses, pcv hose, pcv separator, pcv tube, tube
