Old 06-28-2025, 03:58 PM   #1
Tannero
Drives: 2018 SS / 2021 ZL1
Cam difficulty and expense?
Hey everyone.
I have a 2018 SS and just bought a 2021ZL1.
ZL one is fast as hell to begin with and I just put a XE exhaust on and it sounds awesome.
I’m just wondering I do like the sound of a highlift Cam, how hard and expensive is that to put in a LT four engine.
I would probably pay somebody but all I really want out of it is that nice highlift cam sound the car is fast enough performance is great.
Anyone have experience with just a Cam job I don’t know how much else you’d have to do if you put a high of Cam in?
Tannero is offline   Reply With Quote
Old 06-28-2025, 05:19 PM   #2
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I wouldn't say it's hard, but it's time consuming regardless of if you do it yourself or pay somebody. Not nearly as easy or cheap as the LS motors. See several of our build threads for an idea of what you'd be getting into.
Mods being installed-
Old 06-28-2025, 05:58 PM   #3
atx_traveler
Drives: blue velvet
Why not cam the SS instead?
atx_traveler is offline   Reply With Quote
Old 06-28-2025, 07:29 PM   #4
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
This right here through and through. These aren't as simple as LS cars anymore indeed.
758 HP/ 804 TQ
Old 07-01-2025, 04:50 PM   #5
Tannero
Thanks guys. Will go see the build forum.
Could cam the SS but my wife has that car now and it would drive me nuts hearing that car cammed before mine but is an idea if it’s a lot easier
Old 07-20-2025, 12:15 AM   #6
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Well said Rob. I agree it's not a terrible job, but because there are alot of ways to mess this up, you have to have an experienced friend, our some sharp skills. I have heard of labor costing between $4-5k for the install only... which is one reason why alot of people end up wanting to do this DIY. What did you decide?
Old 07-20-2025, 10:59 AM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
It will cost 5-7k for a cam install with parts, labor, fluids, and tune. It's not hard but it's a lengthy process. Super easy to miss steps. You basically have to tear the engine down to the short block, for that reason a lot of shops pull the engine to complete the job.
Old 07-21-2025, 07:20 AM   #8
Smokin19
Drives: 19' ZL1 A10, w/pdr
To do the cam correctly and utilize it's potential there will be other parts involved. You should also be thinking, lifters, pushrods, springs and rockers to name a few. Not to mention fueling needs like a bigger throttle body. Try to think more in terms of a how each component is needed to support the other to get the best return. JMO
Smokin19 is offline   Reply With Quote
Old 07-31-2025, 07:27 PM   #9
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2021 zl1 a-10 WildCherry
I would say with your location talk to Jannetty......
2021 Wild Cherry ZL1 A10, Sunroof, Data,Red Carbon Interior, Nav, RotoFab Big Gulp , Elite x2ultra, Borla ATAK, Driveshaft shop, BMR susp, Speed covers, intercoolers, ATI , 2650 MAG, DSX lid, 103 NW, TSP Longtubes & cats, LPE, 1le mods, ,LME cover, Katech pump and chain, Trunnions, BTR stage 2, LPE boostapump, Gforce, Speed eng , Granetteli, etc etc
christianchevell is offline   Reply With Quote
Old 08-01-2025, 09:06 AM   #10
clg82
Drives: 2020 Camaro ZL1
The shop I’ve been talking too says they don’t pull the engine for a cam install. What’s the good/bad of doing it this way aside from maybe saving time on labor.
Old 08-01-2025, 09:41 AM   #11
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Some shops do it this way.
In the car:
- Remove the radiator+HX+a/c pack, and discharge/recharge the A/C
- Clean off the gasket surfaces, bolt holes, etc. at odd angles
If it matters to you, you cannot hold the back of the cam while torquing the crap out of the cam bolt (unless you go with a 3-bolt cam where it won't matter). The risk here is stretching the timing chain, though most don't seem to care.
Out of the car:
- Don't have to pull the radiator pack or discharge the A/C
- Can clean everything with easy access
- Can grab the back of the cam and also inspect clutch or flex plate
Six of one, half a dozen of the other. To me, it certainly seems easier out of the car, but then again I'm turning into an old man who doesn't like to contort his body any more than necessary.
I'm sure it's a little less time consuming to leave it in the car, but several of the folks on this forum who have done it both ways have said they would likely just pull the motor given a choice.
I know most of the spotless-reputation shops (Vengeance, Katech, JRE) all pull the motor.
Old 08-01-2025, 10:34 AM   #12
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
When you add a CAM (if it's a lot different than the factory CAM specs), with everything else being the same. Do you lose boost vs boost you had before adding the CAM? Like not much, but still loose say like 2psi to 3psi?
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 08-01-2025, 10:54 AM   #13
KingLT1
KingLT1's Avatar
Anytime you increase flow on the outlet side of the compressor you will see a drop in boost psi. And anytime you increase flow on the inlet side of the compressor you will increase boost psi. How much gain/loss in psi varies on how much restriction was prior and how much flow was increased.
Old 08-01-2025, 11:39 AM   #14
SOCAL.M6.ZLE
Although I have no experience in doing a cam install "in car" I have taken it down enough where I could... and having done my "out of the car" along with an oil pump... I can tell you that I would NEVER want to do it "in car" even if there was a time savings.
Although, putting my "business owner" cap on.. I could see a benefit of reduced liability by keeping the motor in the car, so my guess is that it could be based on liability / risk... not necessarily time.
I am confident that an experienced shop could do it either way with success.
For me, I did NOT want to be leaning in for all of the work, and did not want to mess with the oil pan on my back... so pulling the engine, being able to have better access to all components, as well as the ability to rotate the engine was a plus...
Hope that helps.
