Old 06-27-2025, 07:20 PM   #1
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
Jms voltage booster guide for dummies?
As the title states, the directions are very daunting and tbh, Im not sure If I should attempt it or take it to a shop a few hours away. Do you really have to drop the drivesshaft and such for 2019 zl1's? Can it be done solo? This really makes me nervous, lol, and have no one to assist me. Are their any recommendations for a shop in Vegas that does this? Vegas is only a couple of hours away for me, and I dont want any first timers doing it, unless its me lol, but at this moment, idk If I can.
Old 06-28-2025, 01:22 AM   #2
WiggyB
WiggyB's Avatar
Drives: 2022 Camaro 2SS 1LE
Here's a thread from a quick search with step by step instructions for a ZL1 install.
https://www.camaro6.com/forums/showt...jms+boost+pump
d1sc w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, mamo ptb, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
WiggyB is offline   Reply With Quote
Old 06-28-2025, 07:07 AM   #3
Booher
Booher's Avatar
Tyvm good sir! I looked it over, I think I can handle that, the part that Im most nervous about is setting it, while using an ohmmeter and having someone press the throttle in certain positions. I can't get any assistance so have to solo install it somehow. I also don't have anything to show me me throttle %
Old 07-03-2025, 08:19 PM   #4
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Are you going to be tuning the car? Not sure of all your mods or plans, but if you are using hptuners it will show throttle pedal position. You can also use an obd2 dongle and the torque pro app, should also show throttle position. It's pretty hard to do it yourself as you need someone in the seat reading the pedal position as you read voltage. Guess you could run a tap off the power coming out the jms with a wire running to the cabin where you could read voltage, not sure if that length of wire would effect readings.
Check out my youtube channel
https://www.youtube.com/@evans.educa...ocxUzC1ferqeg8
Full SPL suspension / Ported blower / NW 103mm / Rotofab BG / 2" Headers / Ported heads / Upgraded Valvetrain w/ DOD delete / Custom 38% Cam / C7.R Timing chain / Katech Oil pump / BMR motor mounts and chassis braces / Katech 174* Thermostat / Pierburg Supercharger coolant pump / PLM HX / JMS voltage booster / ATI Damper w/ 8.6 Lower / MM Mild catch can / ADM Resevoir / soon to come...
Rebuilt Engine / XDI +30% injectors / PWR Oil cooler setup / GMS Hood bracket
760 Whp / 700 Wtq E50
Evansa22 is online now   Reply With Quote
