Old 06-24-2025, 01:49 PM   #1
Corbu
Drives: Camaro 2SS
Question Product code for NPP exhaust replacement kit (automatic)
Hi all,
I am sorry if it is has been posted before, I can't find 100% accurate info about it and I thought it is safer to ask here.
I need to replace the NPP exhaust on my car, automatic.
What are the exact GM product codes for the whole replacement kit from the cats back? Quad tip NPP exhaust, automatic SS.
I got the whole thing bent and pushed in by accident and it can't be "stretched" back. The cats are good, the rest has to be replaced with OEM if I want it to sound the same. I don't want aftermarket, I love the original NPP sound with the valve fuse pulled out.
Thank you.
P.S. I can't believe I have been driving this thing for almost 8 years now and I am not ready to part with it yet. I just need its original raspy sound back. Cheers to all that are still enjoying their Camaros.
2017 2SS stock
Corbu is offline   Reply With Quote
Old 06-24-2025, 07:52 PM   #2
I think it's 84897450.
https://www.gmpartscenter.net/oem-pa...embly-84897450
You probably won't like the price, though, if it's even available from the factory (sigh)...
Old 07-02-2025, 08:02 AM   #3
Ericdared
Ericdared's Avatar
Drives: 2022 Camaro zl1
Yeah probably cheaper to find one someone has replaced with aftermarket and get it shipped to you.
Ericdared is offline   Reply With Quote
Old 07-02-2025, 09:18 AM   #4
GreyGhost702
Drives: 2019 Camaro 1SS1LE
Any decent exhaust shop can bend pipe and replace the factory stuff. If everything from the cats forward is good/straight, the only other parts you really need to get are the AFM valve and NPP muffler. Everything else is just pipe.
Edit: FWIW if you still have the factory damaged piping & components, if the AFM valve and NPP muffler are in good shape, the exhaust shop should be able to salvage them and just put them on. As far as it sounding 100% like the factory exhaust, I don't think the crushed vs non-crushed pipe is going to make a difference. If anything you might get a slightly deeper tone in areas where cross sectional area has been increased. I highly doubt you'll be able to notice it any difference in tone it'll be so subtle.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
