![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Driveshaft failed so replace with stock or aftermarket...
So, you may already know from my earlier post on my build thread. I snaped my new Driveshaft Shops 3.25" 1-Piece Carbon Fiber drive shaft in half today. Damage to anything else looks minimal if not NONE! I'm still not sure why it failed. I had the BMR Rear Cradle Lockout and Busing kit installed at the time the driveshaft was install. That's required by DSS for warranty, so it must be important! I know this could be partly based on opinion. But, you guys with builds that have +824rwhp, what driveshaft are you running? Is the stock DS still ok to run at +824rwhp, or is carbon fiber, chrome molly, aluminum etc. required and what size 3.25" or 3.5"? I just don't want to ever go through this again ! Thanks in advance!
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
I'm still running the OEM driveshaft, I give it hell on my setup, but I don't track it.
Carbon fiber driveshafts are not ideal from what I remember. They delaminate or something like that.
758 HP/ 804 TQ |
![]() Drives: ‘23 ZL1-1LE Join Date: Mar 2023
Well you know how bullet proof the ultimate aftermarket driveshaft is….. put the stock driveshaft back in it, and get a proper driveshaft safety loop.
ZLRob & Camfab... I just might be heading that direction !!! Starting to dig into things now! Thanks
![]() Drives: 18 Camaro 2SS Join Date: Jul 2022
Driveshaft
I have a DSS chromoly drive shaft in mine. I've put a couple hundred + 1/4 hits on it and about 8000 street miles.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
Never been impressed with DSS driveshafts. Too many have failed that I've seen. I ran a QA1 carbon fiber driveshaft with my 892whp Hellcat for 3 1/2 years and never had a single issue.
#7 |
#8 | |
Moderator
On the flip side, everyone that I’ve see run QA1 loves theirs.
#9 |
![]() Drives: 2018 zle, 03 cobra, 92 mustang lx Join Date: Oct 2024
aluminum one here in my zle, I have a PST carbon shaft in my race car however its 2600 lbs with me in so the forces it sees are much different, PST says the only way theirs tend to fail is from rubbing. Glad it didn't tear up anything when it failed (as its designed to).
Owner and driver of the worlds fastest naturally aspirated drag radial car. Hays Consulting and Performance
4.58@151 BBC powered 585 ci 9000+ rpm https://youtu.be/wSz2OedlNSI?si=SnPoqreXFQ7NLYX8 2018 ZL1 1LE 416ci LME long block, 2650, reflex port injection, full e85, tick performance tr6060, monster triple disc, DSS drive shaft, g force axles. |
#10 |
Man ! It's such a decision, I only want to be doing this once and for the last time! I've read a lot of good stuff about QA1 DS's... but, now I'm getting wherry of Carbon Fiber. I guess I can't let a bad experience of a bad product, ruin it forever for me! Do I just put the stock one back in and forget about it or is 800+rwhp too much for that ??? UGH !
#11 | |
Moderator
I wouldn’t let your experience with DSS taint your view of carbon fiber. If DSS will warranty it then I’d go that route again. If they act like they usually do when supporting customers and tell you to pound sand then go for the QA1. But you can definitely run the OEM ZL1 DS without losing sleep over it.
#12 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Sorry this happened to you, but luckily no further damage was done. A lot of people recommend the Gulf Coast Driveshaft as a reliable alternative. I don't have personal experience with them myself, but after doing some research, this is what I would choose. I've read plenty of great feedback and positive experiences from folks in the Facebook LT4 group. Their shafts are known for handling high horsepower and torque well, especially in drag racing setups. Definitely worth considering if you're looking for something durable and proven.
I met Mallory (screenshot below) at Cadillac Attack in Orlando, and she is definitely not babying her ZL1.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: SwissZL1 Last edited by swisstyphoon; 06-22-2025 at 02:09 PM. |
#13 |
And sadly, I don't think QA1 makes one for the ZL1. I think they do make one for the SS. Not sure if they're interchangeable though. Quite a few people ran them in the Hellcat community and we all know those cars weight a LOT more than a 6th Gen Camaro. I only know of one that broke, but it wasn't the carbon fiber that broke, it was the adhesive that held it to the yoke and when the customer contacted QA1, they replaced it for free no questions asked and wanted the original driveshaft back to analyze it. That helped them find out they had a bad batch of adhesive in one of their batches and they contacted the customer to let them know why it failed. VERY professional company.
#14 |
Z OH 6 - I think your right, I confirmed the SS will not fit correctly the ZL1, they are not interchangeable. It might be a spacing issue?
I did get the rear broken piece removed last night, wear long sleeved shit and gloved when working with a broken CF part. I feel like I have microscopic fibers of CF in my skin, arms and hands and it's really annoying. This CF DS is only 4mm thick! and is crazy light weight. I have started the process with support where I purchased the drive shaft from and hopefully they can/will get me a replacement. But, not sure what one will go back in my car though!
