![]() Drives: 2022 Vivid Orange LT1-M6 Join Date: Dec 2015
Broke through while elongating holes on 95mm TB. JB weld?
I was already on the fence about getting a ported 95 or a 103, and now while elongating the bolt holes I punched through. Anyone do this and fixed it?
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
By punched through, I am assuming you mean pulled the elongation out so far it broke through the edge of the casting? And only on a single hole? Pictures might help for suggestions, but just off imagination I would suggest if you aren't adept at welding try taking it to a machine shop and have them put the metal back. While you're there, give them the dimensions needed for the holes, and they can set it up for you. I think this method cuts the least corners and saves you the most time/headache. Not the cheapest method, but it will make it right.
The most cost effective might be just ordering a new TB, or the TB you want that is already set up for you, if the above repair method might cost you similar or more.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
Pic
To be honest, while it's probably not preferable, that hole is just in the exterior casing. I don't think it's going to hurt anything. If the bolts are in alignment and fit to the manifold, I'd send it.
