Old 06-21-2025, 07:26 AM   #1
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
How much HP for tune
Sup guys! I'm broke and trying to talk myself into just biting the bullet and get the car tuned. I searched for a while and couldn't find the answer, so here I am. Any idea how much a tune, jms voltage booster, zr1 tb, flexfuel, rotofab with velossatech, and secondary cat delete would make on 91 and on e85? Am I even going to notice it without e85? I have to drive 3 hours to get ethanol so won't be getting very often. I know this has been asked many times in some form or another but they must be buried deep as I can't find them. Car dynod up in Vegas at ls fest 2 years ago at 538 hp. I dont think there are anymore cheap mods I could do before a tune besides swapping pulleys, but its too hot here and constantly running 91.
Old 06-21-2025, 10:46 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Is your ECM already unlocked? If not, that and licensing are going to be more $$$ on top of a several hundred dollar tune. I think I paid $250 or something, for a simple 2650/RFBG tune 4-years ago (Ben Charles) when I first got into this platform, not counting the $200 in licensing credits for the ECM. E85 is GREAT for this platform and is worth if over 91 FOR SURE, if you can access it. I'm not sure you have enough high side to too much over 700, but my brain's a little foggy at the moment. I believe a guy on YT (used to be) was able to get near 700, with a slightly different combo (but not too much) and get close on something like E30. He got into the 9s on that. Anyways - I don't know, without cooling mods and octane booster that you'll get too far on 91. I don't think I was able to run much more than about 16* at 14-psi on 91. With about 93-94 octane, with booster, I could find up to about 20-21*, but that was pretty aggressive. Maybe a better alternative, to keep performance at low $$$, is a good tune, on octane booster. Maybe look into an KONG/JOKERZ blower port when you can (which would require a tune). Maximizing the 1.7 for maximal $$$:performance on octane booster to help extend the fuel system might be your best bet, IMHO. Br careful with the MTBE though, as it can kill cats' and sensors.
Shops seem to be validating boosters like VP Octanium/ Boostane/ etc (I also had good experience on RaceGas product, too) so that's, probably the most effective bang for the buck in a case like you're describing. E' is better (because of the chamber cooling from the alcohol) but requires A LOT more fueling.
'20 ZL1 Black "Fury"
Old 06-21-2025, 11:42 PM   #3
Booher
Booher's Avatar
I had my ss tuned, so i know about the credits, its around 1k for a tune. I also looked into porting the blower, but am limited on funds. So, sounds like it's not worth tuning it untill I get more mods. I appreciate your input good sir!
Old 06-22-2025, 10:30 PM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
See - you were already on the right track. If you want to maximize your set=up, maybe it has some value, and if that tuner with make minor adjustments for a ported blower, that might not make getting one now that bad. But you have to check first, and if you need help, don't hesitate to PM me.
Old 06-23-2025, 03:48 PM   #5
Booher
Booher's Avatar
I appreciate the help man! I'll message the tuner to see his thoughts as well. I just may hit you up on that offer at some point!
