![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
Bellmouth for rotofab sold
Sold
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS Join Date: Dec 2009
Does this still use an air filter? And does improve performance??
Orange Krush II
#3 | |
Moderator
No air filter, so you’re taking a risk. It’s worth 25 WHP or so on a 1K WHP car You’ll need a separate tune to run it, it drastically changes your MAF readings.
Do you have deminsions just curious if it could work with my Z28 CAI?
Orange Krush II
My caliper is showing a diameter of 152.5mm on the inner part that would slide over the intake tube
