Old 06-16-2025, 12:54 PM   #1
jessica.cathey
Drives: 2021 Camaro 1LT
I need guidance (please)
I am a new owner of a Camaro 1LT 2021 and since getting it, I seem to be having nothing but issues. I just had the thermostat replaced which thankfully was covered under the warranty but now just approx 1 month later, my engine light was back on so I took it to the dealer and they are quoting me over $1200 for a cooling fan motor assembly. Is this not covered as it seems to be relative to the thermostat? Any advice would be great.
jessica.cathey is offline   Reply With Quote
Old 06-17-2025, 03:57 PM   #2
Alan47717
Drives: 2022 1LT RS 2.0t/6spd
Unfortunately, they will stick with the "It's not covered under the power train 5 yr warranty and not related to the thermostat issue" line. It's what they do. I had a suspected fuel leak on a different vehicle and was informed that even if it was a leaking injector it wouldn't be covered, a FUEL LEAK! The power train warranty is extremely limited in what parts are covered.
Alan47717 is offline   Reply With Quote
Old 06-18-2025, 12:01 PM   #3
GreyGhost702
Drives: 2019 Camaro 1SS1LE
Welcome to the Forum.
Just FYI, the part is about ~$300 if you are so inclined to DIY. So it looks like about $900 in labor and part markup you'd be saving.
Kind of weird the fan is toast in such a young car. Parts do go bunk I suppose. Kind of wonder if they were throwing parts at the CEL? First a T-stat, now a month later it's back and they're gonna throw a fan at it. Do you know what the CEL code was the first time and what it is now?
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
