![]() Drives: 23 Camaro ZL1 Join Date: Mar 2023
Detailing Wheel Covers
I’m tired of washing my car, blow drying it, parking it in my garage, only to find my brakes are rusted to the rotors. This happens in a matter of a couple days. I’m considering buying detailing wheel covers for when I wash my vehicle. Does anyone have any experience/suggestions? I appreciate everyone’s help.
I drive the car about a mile after washing and drying, braking often to stave off residual water and clean away any surface rust. Never had an issue with pads sticking, except the one time I stupidly forgot to do this routine. My car sits in the garage a lot, it isn't a daily driver.
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Problem solved! https://www.amazon.com/gp/product/B0...1VCSLB0K&psc=1
I wash my car after every day I drive it. I use a dry dryer to blow the water off it (I never use a towel or cloth to dry it. I also use Gyeon Wet Coat, it's amazing ! I detail it every weekend. I never have issues with rust on my rotors since using Hydes Serum ! I hope that helps!!!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#4 | |
Thank you |
#5 | |
Thank you for your suggestions |
It's a spray coating. You can use it on the wheels, but it's typically used on the entire car. It has nice hydrophobic properties. It wouldn't do anything to help your rust issue, 2023 ZL1 Auto was just letting you know he uses that for a coating on his car.
My car is a daily driver, so it doesn't sit for extended periods. Like others, I often drive it after detailing to remove the rust. I'm in a Facebook group of professional detailers, but haven't heard of anyone using the wheel covers. Wheel & tire cleaning is always part of the process, so that's probably why they don't use covers.
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
#7 |
Thank you Al Oppenheiser!
TL/DR: Don't put it away with wet brakes.
The problem: Water will dissolve into the transferred binder layer on the rotor, as well as into the pad itself and turn the binder into glue, which then dries as it sits and bonds the pads to the rotors. The solution: An easy 3 minute drive around the block will dry out the pads and rotors enough that then they won't stick. EDIT: Yeah if you live on a dirt/gravel road that will make this challenging. Maybe driving the car back and forth a few times down the driveway while riding the brakes to get some heat into them will help. The anti-rust spray is certainly worth a shot for the money. If not, go for the RV wheel covers.
#8 | |
Thank you for the suggestions. |
#9 |
I washed my car yesterday. Attached is a photo during washing and after spraying Hyde's Rust Stopper on the rotors, then a photo from this morning before driving the car to car's and Coffee... NO RUST !!!!!
#10 |
Thank you…the pic from today looks great. I can’t thank you enough for the help…greatly appreciated
#11 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Buy some Atom-mac, put it in a spray bottle.
Spray your rotors after you're done washing your car. No worries going forward. One of the best things I learned from the 911 crowd.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Ive had rotors frozen once that so bad I really had to work it hard to get loose and that was with Z26 pads on it.
#13 | |
